Mazdaspeed Forums
-   Damond Motorsports (http://www.mazdaspeedforum.org/forum/forum/f661/)
-   -   Oil Drain Line Flange pre-buy (http://www.mazdaspeedforum.org/forum/forum/f661/oil-drain-line-flange-pre-buy-198691/)
Matt@DamondMotorsports 02-11-2016 10:57 PM
Okay, you guys asked for this, and now you are getting antsy, so we want to get these out ASAP. As a good favor to the MS6 community from DM, let us present our Oil Drain Line Flange.
https://damondmotorsports.com/collec...l-drain-flange
This is for the flange that mates to the block and the -10AN 90 ORB fitting that goes into the flange. Depending on how well these do, we may offer a full line and fitting kit, but for now we want to get the most crucial components out, so you can run with it from there.
Price is going to be $95 Free US shipping. That includes the flange, and this ridiculously expensive fitting. We’ll also be offering the flange and fitting separately for $35 and $60 respectively. Note: we grind the washer down on the fitting, as to clear access for the bolts.
Pre-buy is open now, and closes in 1 week, so order ASAP. We’re doing a first round of 20 of these, if there’s more than that many people in the pre-buy, we’ll be getting more. Estimated delivery is 2.5 weeks. I’d say “2 weeks” but then you guys would never get this kit.
http://i797.photobucket.com/albums/y...pszccotwe7.jpg
http://i797.photobucket.com/albums/y...psgufne7u4.jpg
Mazdazilla6 02-11-2016 11:24 PM
First. Ordered.
Does it include the bolts?
Matt@DamondMotorsports 02-11-2016 11:34 PM
Quote:
Originally Posted by Mazdazilla6 (Post 3024170)
First. Ordered.
It does. You can re-use the stock ones, but we include allen bolts.
MSP611 02-12-2016 12:07 AM
What u mean by shave down the washer??
What kinda gasket is used between block and new flange? Stock type?
Just ordered mine as well!!
Sent from my Nexus 7 using Tapatalk
littleloogy 02-12-2016 12:27 AM
If you look closely at the last pic, you can see the washer between the mounting plate and the 90 degree fitting is shaved to allow the Bolts to line up properly. It's common to shave washers especially in a trial run. I am sure if these become popular Damond Motorsports will custom make their own washer.
Sent from a Galaxy far, far away...
season_of_ages 02-12-2016 03:56 AM
Just place my order
Code Monkey 02-12-2016 05:53 AM
Ordered.
wes3id 02-12-2016 06:43 AM
ordered
Code Monkey 02-12-2016 06:48 AM
Stock gasket. :)
Omega 02-12-2016 09:19 AM
Ordered
ms6mil 02-12-2016 09:38 AM
Ordered
MSP611 02-12-2016 11:49 AM
Quote:
Originally Posted by ms6mil (Post 3024287)
Ordered
not tryna hijack thread or anything but breh ur car looks dope in ur sig... i was thinkin of gettin a professional photoshoot done with my car when its done
rob ms6gt 02-13-2016 09:13 AM
Any way to get more than a week on this? I'll buy just the flange if I have to, but I'd like to wait till I can afford the whole thing. If 20 are not sold this week will they be no longer available?
Sorry, poor.
edit: Ordered. Fuck it. Made it happen.
DingoDave 02-13-2016 04:56 PM
Ordered!
Farhan@DM 02-15-2016 06:22 AM
Quote:
Sorry, poor.
Glad you were able to get it.
For anyone else in a similar situation, your best bet is to buy the flange now, and buy the fitting when you're ready. You can buy the fitting yourself, and modify it. It's an available P/N from XRP (currently on amazon for ~$60), and taking the washer diameter down is nothing to be afraid of.
We'd rather not delay release, as there are people with builds coming up very soon that would be upset.
MSP611 02-15-2016 06:36 AM
1 Attachment(s)
Thts wat im talkin about....
wes3id 02-15-2016 08:27 AM
I bought this flange and the 90* adaptor. i will be installing a BNR s3 soon and am wanting to go ahead and do the return line at the same time. can anyone give me a parts list i will need to build the return line for the BNR so i can get it ordered? also does anybody know the exact size hose that goes from the bottom of the turbo to the TC?
Code Monkey 02-15-2016 08:41 AM
^ I would use the OEM line on the BNR.
wes3id 02-15-2016 08:45 AM
Quote:
What is your reasoning? I think i have a small leak at the block flange as it is a little wet around it. i am installing the kozmic feed line as well, so figured i'd do both and be done with it.
Code Monkey 02-15-2016 08:57 AM
Quote:
Probably easier, unless you have the engine out. :D But if you still want to pursue it, a 45* and a 30* AN fittings worked for my mockup, got them from Treadstone.
wes3id 02-15-2016 09:00 AM
Quote:
ya i've read that it is a PITA with the engine and TC in place, but still possible. what flange did you use for the turbo side?
Code Monkey 02-15-2016 09:06 AM
Quote:
This one, I don't like the slotted holes as you can get the flange off center so make sure to install it on the turbo while the turbo is out.
wes3id 02-15-2016 09:11 AM
Thanks, appreciate it man.
MSP611 02-15-2016 09:31 PM
Quote:
Have u found treadstones AN fittings are better priced? Cuz holy fuck these things get expensive.. Just for some e85 nylon braided hose (running from hardlines in rear to my pump and a return line from fpr) and an fittings i spent like $500.. I did buy a few extra just in case I needed diff angles but fuck me $500 for some hose and fittings.
Code Monkey 02-15-2016 09:46 PM
No idea, I bet you can look around and find something a bit cheaper though.
MSP611 02-15-2016 09:54 PM
Tht was from jegs, summit was similarly priced
r3d 02-16-2016 08:20 AM
Finally! ordered
wes3id 02-17-2016 01:04 PM
Hey man, did you use the paper gasket under that flange? or did you modify the stock metal crush gasket? i plan on using copper spray on whatever gasket works better for extra leak protection.
Code Monkey 02-17-2016 01:20 PM
Quote:
This flange has an integrated o-ring, no need for a gasket or copper spray. :)
wes3id 02-17-2016 01:23 PM
Quote:
ya i got it in today and saw the o-ring on it, was just curious if a gasket was still needed. have you had any leak problems with it?
Code Monkey 02-17-2016 01:40 PM
Quote:
I only test fitted on a spare engine, have not used the line yet on a running engine.
rob ms6gt 02-18-2016 05:17 AM
That o-ring is a lifesaver for on car installs tho
Matt@DamondMotorsports 02-18-2016 02:53 PM
Order while you still can! At 11:59 the pre-buy ends, and the availability to order will cease.
Remember you can always order the $35 flange, and get the fitting elsewhere down the line.
Thanks to everyone who has ordered so far! You'll be receiving a confirmation email when they ship out. We're estimating delivery to your door the first week of March.
rob ms6gt 02-18-2016 05:39 PM
Quote:
Not always! Only till about 11:59 :biggrin2:
qtrmile beast 02-19-2016 12:46 PM
http://i206.photobucket.com/albums/b...pshmrwgz2l.jpg
Has any one seen or tried this flange? Its angled at 45o already. Not sure on the clearance for the transfercase though.
Mazdazilla6 02-21-2016 01:01 PM
Doubt it will clear. I bet it's fine without a fitting but once you put one on it's probably too long.
Code Monkey 03-01-2016 06:06 PM
Aaaaaand.... they shipped!
Matt@DamondMotorsports 03-01-2016 06:06 PM
Got all shipped out today!
It was a fun rush, as my UPS guy delivered to me at like 5:45, and I had to be at the post office before 6:30.
Remember to use some oil on the threads of the flange when installing the fitting! For those who ordered the ORB fitting, remember to tighten the jam nut on it when installing into the flange. We also included a couple allen bolts with the flanges.
Any questions when you guys get it, feel free to ask!
nindoja 03-02-2016 07:59 AM
The flange has threads??? Or did you mean oil the bolts?
Farhan@DM 03-02-2016 08:02 AM
Quote:
Fitting threads into flange, flange bolts to block.
Page generated in 0.21516 seconds with 11 queries
