| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
| Neutral : +1 score Shift weights can't really cause lockout. That's a function of geometry, parts conditions, and operating condition. In general, if simple cable adjustment can't get your shifting to be consistent with a new part, take that part off. You shouldn't have to be playing with weights or fluids to make a part work as it is advertised to. If the problem persists, you may have other mechanical issues.
__________________ |
| The Following User Says Thank You to Farhan@DM For This Useful Post: | aackthpt (02-03-2017) |
![]() Join Date: Mar 2014 Location: Sedalia,MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score
I understand the adjustment to the cable. Shifting into third is fine when driving normally. I only get lockout during wot occasionally with the clutch all the way pressed. So ill try the stock shift weight and see what happens. If the problem is still present then ill look into other things. Maybe the transmission. Sent from my iPhone using Tapatalk | |
| Neutral : +1 score
__________________ | |
| Not Ranked : 0 score |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score ...Good motor mounts help with that 3rd gear issue.
| The Following 2 Users Say Thank You to aackthpt For This Useful Post: | Mauro_Penguin (02-05-2017), sharksinspace (02-03-2017) |
![]() Join Date: Jan 2014 Location: San Diego, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
| Not Ranked : 0 score Removed my JBR ssp last night and got the damond plate in. I'm running it currently with no weight to get a feel for things before adding weight. I only have a JBR shift weight as i lost my stock weight. Currently: -Damond ssp, 3 inch shift extension, jbr weighted knob, jbr shift bushings I really like the feel of the DM ssp. There is a noticeable difference in ease of getting into gears while shifting. The notchiness is definitely gone when compared to the jbr plate. It just clicks nicely into the next gear. This was about the only thing i could not stand about my car. I didn't think switching plates would warrant any change, but yet again you guys made an awesome well thought out product. Slowly but surely all the JBR parts are being phased out with your motor mounts for the least NVH, and now this SSP. Good work guys!
__________________ (PD tuned) 397hp/358tq 91/100% meth BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff |
| The Following User Says Thank You to iamareios For This Useful Post: | Farhan@DM (02-13-2017) |
| Not Ranked : 0 score Long story short, after trying many different combinations I settled on the damond plate with my JBR weighted knob, shift extension, and lighter than stock shift counter weight off eBay. In my opinion this setup suits me well and is refined but buttery smooth. The JBR counter weight was just too unbalanced. No weight was sloppy. Hope this helps!
| Not Ranked : 0 score Sauce on eBay weight?
| Not Ranked : 0 score Got this one in black. It's pretty light NYPPD Short Shift Counter Weight Blue Mazdaspeed 3: 2007 08 09 10 11 12 13 & up | eBay
Stock: 580g JBR: 354g Cobb: 280g (? calculated, unconfirmed ?) The listing claims "75% reduction", I don't really trust that but it would result in 135g. Since it's aluminum it would make sense that it would be quite light.
__________________ 2013 'speed3, silver Stage Bro | |
| Not Ranked : 0 score I did not weigh it unfortunately. It looks similar to this torque solutions shift weight TORQUE SOLUTION SHORT SHIFT WEIGHT FOR MAZDASPEED 3 2010+ | eBay I'm sure you could contact the seller through ebay to find out.
![]() Join Date: May 2015
Rep Power: 62 ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Bumping thread for review. Ordered SSP from DM, shipped fast, and arrived to me fast also, which is a plus. Install took around half an hour due to cold weather. You could easily install this in 10 minutes or less if you have all the tools in front of you. The part itself is high quality, the only thing I would add to it would maybe a small laser engraved logo on it. I would have paid extra for that. Initial feel: Definite difference over stock, throws are shorter, and more precise, this is how the car should have came from factory. The shifter itself is also a little bit tighter. I am using the OEM weight and OEM shift knob. Next will be an aftermarket weighted shift knob as the leather on mine is wearing out and looks like shit. For those TLDR; Fast shipping by seller, quick/easy install, noticeable improvement over stock, highly recommended. |
| The Following User Says Thank You to MaxSpeed13 For This Useful Post: | Farhan@DM (03-20-2018) |
| Not Ranked : 0 score You are welcome. I figured as much. I just don't want to get another leather wrapped shift knob that will wear out and look like shit after 2 years. I will try and look for a SS one that is roughly the same weight as OEM. |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Tomei shift knob(70mm), Damond Motorsport SSP and Cobb shifter weight = very good setup Last edited by dix2003; 03-20-2018 at 04:53 PM. |
![]() Join Date: Feb 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score I just ordered my SSP from you guys after reading all of the great reviews here. I will also be sure to leave one on your website after installation. Thank you all for the information and a special thanks to Damond for continuing to make high quality parts for our platform. |
| The Following User Says Thank You to pyrophelia For This Useful Post: | TruckHer (04-28-2018) |
| Display Modes | |
| NEW!! JBR MAZDASPEED 3/6 Adjustable Short Shift Plates in Stock!! | JBR | JAMES BARONE RACING | 58 | 03-30-2015 01:06 PM |
| JBarone Short Shift vs J-speed short Shift | jallways | 2010 MS3 - Engine, Transmission & Driveline | 97 | 05-27-2011 11:33 AM |
