| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
| Name is longer than yours ![]() Join Date: Mar 2013 Location: Chicago, IL
Rep Power: 785 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Neutral : +1 score The Damond Morotsports Short Shifter Plate(SSP), is a great way to shorten the shifter throw on your Mazdaspeed3 and Mazdaspeed6. The Damond Motorsports SSP works by moving the ball on which the shifter cable is mounted, closer to the input selector fork, thus reducing the throw of the shifts. The shifter itself retains the factory height. The SSP attaches to the transmission shifter assembly, in a slide over and under fashion, and is locked into place with the included hardware. The hardware supplied allows the SSP to be installed with or without the factory shift weight. We have spent much time in the development of our SSP, to provide a great feeling shifter, without the risk of any binding. Our SSP was designed to offer the absolute most in reduction, without the shifter cable boots rubbing up against the shifter assembly. The overall goal was shift feel, where reduction came second. Our SSP's do not use any standoffs, and do not drastically raise the shifter ball assembly, both of which that could result in binding or improper shifter feel. The Damond Motorsports SSP's are machined out of aircraft grade aluminum, for strength, and to keep less weight on the shifter assembly. http://damondmotorsports.com/collect...eed-6-all-year Price $55 free shipping in the US Last edited by Matt@DamondMotorsports; 10-28-2014 at 12:24 PM. |
| The Following 8 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | blackmicamps6 (05-07-2013), Code Monkey (03-22-2013), Etipp98 (03-22-2013), Hush (03-22-2013), InkedInspector (10-28-2014), KCMS3 (12-23-2014), Poohster (05-04-2013), WetzMS3 (10-27-2014) |
![]() Join Date: Oct 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 603
| Not Ranked : 0 score When is anodizing happening?
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP RPM: Sport Springs, Shark Fin, LED side markers CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score It's happened and the gold shift plate looks glorious.
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following User Says Thank You to macdiesel For This Useful Post: | Farhan@DM (10-24-2014) |
![]() Join Date: Aug 2012 Location: Montgomery, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
__________________ 2011 Black Mica with Tech package. Mods: AP, AT Internals, HTP 3" intake, OBX TP. XP5263 plugs. Tune by Kent |
![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score I like the look of this one. Most of the other manufacturers go too extreme and it sacrifices shift feel (smoothness), etc. This looks like a nice happy medium. I would love to see some user reviews...
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray |
| The Following 2 Users Say Thank You to TORQUERULES For This Useful Post: | Koke382 (11-17-2014), Matt@DamondMotorsports (10-27-2014) |
![]() Join Date: Jan 2011 Location: IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 960
| Neutral : -1 score
__________________ 07 True Red Mazdaspeed 3 GT - Totaled 2/7/2015 15 Soul Red Mazda3s GT HB | |
| The Following 2 Users Say Thank You to naoandlater For This Useful Post: | Farhan@DM (10-27-2014), TORQUERULES (10-28-2014) |
| Not Ranked : 0 score Thanks.
Thanks.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray Last edited by TORQUERULES; 10-28-2014 at 09:48 AM. Reason: MSF Database - Automerged Doublepost | |||
| The Following 3 Users Say Thank You to TORQUERULES For This Useful Post: |
| BrownBear ![]() Join Date: Apr 2014
Rep Power: 632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 468
I believe there are reviews on the website as well. It was designed out of necessity because I didn't like long throws, and the competitor SSP I had on my car felt terrible. Feel was the primary objective with this. 50K+ miles later, still feels great.
__________________ | |
| The Following 2 Users Say Thank You to Farhan@DM For This Useful Post: | TORQUERULES (10-28-2014), WetzMS3 (10-27-2014) |
![]() Join Date: Dec 2011 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 966
Groans: 127
Groaned at 24 Times in 17 Posts
@TORQUERULES;
__________________ 2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna FreekTuned ![]() | |
| The Following 3 Users Say Thank You to blackmicamps6 For This Useful Post: |
| Not Ranked : 0 score I've got about 15k on mine and works like a charm. None of the 3rd gear lockout that I have read some people experience on other SSP's.
| The Following 3 Users Say Thank You to WetzMS3 For This Useful Post: |
![]() Join Date: Jun 2012 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,245
| Not Ranked : 0 score I have 25K+ on mine and about 5K with the plate and TWM full replacement combo, still fills good and no lock out or missed shifts.
__________________ 2012 Liquid Silver Metallic MazdaSpeed3 with Tech Package. South Bend Clutch Stage 3 Endurance | TWM Full Replacement Shifter | Synapse Engineering BPV | Autotech Internals | Grimmspeed EBCS - 3port | NGK 1 Step Colder Plugs | CNT Catless DP and CBE w/resonator deleted | COBB AP - E35 Tune | HTP 3.5" Intake w/ AMSOIL Dry Filter and Pre-Filter | HTP Battery Tray w/ Energizer 51R | CP-E TMIC | CorkSport DISI Silicone Boost Tubes | Damond Motorsports/Saikou Michi Co. Stage2 OCC | Damond Motorsports Short Shift Plate | Sure Countershift | BOSCH 3 Bar MAP w/MattJackson86 PnP Harness | JBR Rear Sway Bar | JBR EGR Block Off Kit | JBR Manifold - TIG | JBR Throttle Body TIG & Coolant Bypass | JBR 88a RMM | JBR 88a TMM | JBR 80a PMM |JBR DISI Bypass Valve Hose | Ported and Polished Intake Manifold DIY | RX8 Wheels w/ Nitto Motivo 235/40/18 Tires | CP-E Towplate | DIY Custom 600g Shift Knob | Redline Tuning Hood QuickLIFT | 30% / 15% Tint | Craven Speed Stubby Antenna | Broadway 400mm Rear View Mirror | Debadged Mazdaspeed 3 Waiting to be installed: Devil's Own Stage 2 DVC-30 Meth Injection | Damond Motorsports Meth Throttle Body Plate On Order: Coming Soon: DIY Projects: FYCN - TEAM LBN BEERS - FYCN-TEAM MUMFORD - FYCN |
| The Following 3 Users Say Thank You to SparkySparks For This Useful Post: |
| Police ![]() Join Date: Jul 2013 Location: Louisville, KY
Rep Power: 2719 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,545
Groans: 312
| I have a review for you. Matt......Damond. Matt Damond!!!!
| The Following 3 Users Say Thank You to InkedInspector For This Useful Post: |
![]() Join Date: Sep 2012 Location: Downers Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,033
| Not Ranked : 0 score My review is on the website, but I've had it on for a few K miles now and I haven't had any lockout issues. In fact after getting used to it, I feel like shifting feels much better and snappier.
__________________ 2012 CWP w/ Tech; Damond Motorsports RMM; AT Internals; CS Stage II Intake; Cobb DP; Phate Tuned; KW V1 Coilovers; Damond SSP; DM OCC |
| The Following 4 Users Say Thank You to Chuthor For This Useful Post: | Farhan@DM (10-28-2014), InkedInspector (10-27-2014), Matt@DamondMotorsports (10-28-2014), TORQUERULES (10-28-2014) |
Groans: 312
| In all seriousness, I installed it this weekend. Shifts feel great, no lock outs, and I took some back roads and really put it through the paces. A few ffs at 6k from 2nd to 3rd gear, low rpm shifts cruising, pretty much any thing I could think to do. It feels better than it ever has, throws are perfect, not too short and no feel sacrificed.
| The Following 4 Users Say Thank You to InkedInspector For This Useful Post: | Farhan@DM (10-27-2014), Matt@DamondMotorsports (10-28-2014), TORQUERULES (10-28-2014), WetzMS3 (10-29-2014) |
| Not Ranked : 0 score You guys make this worth it.
| The Following 6 Users Say Thank You to Farhan@DM For This Useful Post: | Chuthor (10-28-2014), InkedInspector (10-27-2014), Matt@DamondMotorsports (10-28-2014), naoandlater (10-28-2014), TORQUERULES (10-28-2014), WetzMS3 (10-29-2014) |
![]() Join Date: Feb 2012 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,441
Groans: 88
| Not Ranked : 0 score I swore off shift plates as a bad idea after my and others' experiences with the other options available on the market, but now all of these reviews have me curious if there might be something to this... I've been running the Perm butt plug and no shift weight for the last year and a half and it was like an awakening after taking my previous shift plate off. They may shorten the throw but they really do ruin the feel of the shift and make it harder to execute a clean shift. I'm still not 100% sure how it is that this product gets around the pitfalls of the other plates on the market with what appears to be a fairly similar design. What is the magic here? Is it just that it doesn't shift the cable over as far as the SURE to avoid the rubbing problem and doesn't lift the attachment point as high as the JBR (which was done to avoid aforementioned rubbing)? I see mention of moderation, but does this allow for enough change in throw to really be worth it? Sent from my SCH-I605 using Tapatalk
__________________ 2012 LSM Mazdaspeed 3 -- sold 06/2015 ![]() Cobb AP -- 3" SRI + TIP -- gutted mid-pipe -- CX Racing FMIC -- JBR 88duro Mount Trilogy -- GrimmSpeed EBCS -- 3 Bar Map Sensor -- Kozmic vented OCC -- Synapse DV -- Magnaflow CBE -- DDM 55w 5000K low beams 4 gallon E85 mix self tune 314/370 Dynojet 2005 Black Mica Mazdaspeed MX-5 ![]() Bone stock so far |
| The Following User Says Thank You to Darth_Nuruodo For This Useful Post: | Matt@DamondMotorsports (10-28-2014) |
| The Following 3 Users Say Thank You to Farhan@DM For This Useful Post: |
The goal here was to make something that would allow for the most throw reduction without raising the mounting pivot point, and keep the cables from rubbing. Keeping the pivot point low doesn't alter the geometry, where you would have have the cables tweaked if it was mounted high up, providing poor shift feel. Not having the boots rub, is pretty self explanatory for feel, as there's no obstruction delaying the smoothness of operation. Also in keeping it not too far moved over, it again doesn't tweak the cables. I ran one on my MS6 I built for 15k miles, and I loved the shift feel. I ran a COBB knob with the Stratified extender, and removed the shifter weight. Removing the weight on the trans end made sense to remove the weight on the knob end, and it made for a great effortless shifter. I have a couple unfinished plates sitting around, one that I was gonna use on my 5, I'm sure we could work something out, if you'd like to try it on your car. | |
| The Following 6 Users Say Thank You to Matt@DamondMotorsports For This Useful Post: | blackmicamps6 (10-28-2014), Darth_Nuruodo (10-28-2014), Easter Bunny (11-03-2014), InkedInspector (10-28-2014), naoandlater (10-28-2014), silvapain (11-02-2014) |
Groans: 88
__________________ 2012 LSM Mazdaspeed 3 -- sold 06/2015 ![]() Cobb AP -- 3" SRI + TIP -- gutted mid-pipe -- CX Racing FMIC -- JBR 88duro Mount Trilogy -- GrimmSpeed EBCS -- 3 Bar Map Sensor -- Kozmic vented OCC -- Synapse DV -- Magnaflow CBE -- DDM 55w 5000K low beams 4 gallon E85 mix self tune 314/370 Dynojet 2005 Black Mica Mazdaspeed MX-5 ![]() Bone stock so far | |
| The Following 3 Users Say Thank You to Darth_Nuruodo For This Useful Post: |
![]() Join Date: Jun 2012 Location: Summit Point, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,433
__________________ FreekTune GT2871r- 402/402 [SIGPIC][/SIGPIC] | |
| The Following 2 Users Say Thank You to Smelson For This Useful Post: | InkedInspector (10-28-2014), Matt@DamondMotorsports (10-28-2014) |
![]() Join Date: Sep 2013 Location: Tacoma, WA
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 382
__________________ 2011 Mazdaspeed 3 [Sold] 2013 Ford F-150 XLT 3.5 Ecoboost | |
Groans: 312
| I'll get you some pics of the plate installed with the shifter in a few different gear positions later, you can see there are no clearance issues or signs of rubbing. Plus I think it's the fact that this isn't an extreme throw reduction, noticeable, but a good compromise to allow it to function properly. Going on three days now, and I have intentionally thrashed my car trying to create lock outs, or breakage, because I know of all the pit falls with the other SSPs.
| The Following User Says Thank You to InkedInspector For This Useful Post: | Matt@DamondMotorsports (10-28-2014) |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score I have the twm full replacement. And while it tightens everything up, it makes for some very stiff throws without an extension. Feel is definitely more important than length of throw in my opinion.
__________________ 3rd rebuild on the way...maybe... |
| The Following 2 Users Say Thank You to Cheapspeed For This Useful Post: | InkedInspector (10-28-2014), Matt@DamondMotorsports (10-28-2014) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Okay, so how well does it work with the stock weight? I have a 621g knob. I have a stock weight cut down I could try as well...
![]() | | #25 | ![]() |
Groans: 312
| I have the stock weight with a 500g Maisonvi knob, feels great.
| The Following User Says Thank You to InkedInspector For This Useful Post: | TORQUERULES (10-28-2014) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Thanks that helps. I could always use the stock knob if need be. So, no thunk going down into 1st because of too much weight?
![]() | | #27 | ![]() |
Groans: 312
| No different than it ever was stock.
| The Following User Says Thank You to InkedInspector For This Useful Post: | TORQUERULES (10-29-2014) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Thanks so much for the help. :-)
| The Following User Says Thank You to TORQUERULES For This Useful Post: | InkedInspector (10-29-2014) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Fuck the hand outs, ordered a gold shift plate to peacock in the engine bay. Hopefully it'll rid the corksports notchiness
| The Following 4 Users Say Thank You to macdiesel For This Useful Post: | Easter Bunny (11-03-2014), Farhan@DM (10-29-2014), InkedInspector (10-29-2014), Matt@DamondMotorsports (10-29-2014) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score @kevdog;
![]() | | #32 | ![]() |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score I got my shift plate today. Fast shipping! I wanted to share pics of the product and the finished install. ![]() Edit: Generally I don't mess with a shifter unless there is a need for improvement. I have been looking for short shift plate for a while but I was unhappy with what was out there. Damond short shift plate just works right out of the box and the design appears to be more robust than others. There are no adjustments to fiddle with. This shift plate may not offer the shortest throws but shortens it without excessively raising the cable connection and zero rubbing. It comes with all the necessary hardware. You can delete the counterweight if you like but as you can see I choose to keep my aftermarket shift weight on. Install was a breeze...I think it took me maybe 10 minutes max. Thanks Damond!
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT Last edited by tegxsi; 11-02-2014 at 12:30 PM. Reason: comments on shift plate |
| The Following 7 Users Say Thank You to tegxsi For This Useful Post: | Farhan@DM (11-10-2014), Finchee (05-17-2015), KCMS3 (12-23-2014), license2ill (02-24-2015), Matt@DamondMotorsports (11-02-2014), TORQUERULES (11-03-2014), WetzMS3 (11-04-2014) |
![]() | | #33 | ![]() |
I got mine today. Install and review soon.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray | |
| The Following User Says Thank You to TORQUERULES For This Useful Post: | Matt@DamondMotorsports (11-10-2014) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Set it and forget it. Installed over the weekend, alls I'm gonna say is if you don't pick up the gold something's gotta be wrong with you. Sent from my iPhone using sausage fingers
| The Following 2 Users Say Thank You to macdiesel For This Useful Post: | Farhan@DM (11-04-2014), Matt@DamondMotorsports (11-10-2014) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score It's on. Haven't driven it yet. Sent from my Nokia Lumia 1520 using Tapatalk
![]() | | #36 | ![]() |
Groans: 87
| Not Ranked : 0 score It's a little more notchy but that's expected with any short shifter. I was worried about my 3rd gear issue coming back. With the stock shift weight I occasionally had trouble getting into 3rd. Changing the shift weight alone solved that for me. So far I have no complaints...
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following 3 Users Say Thank You to tegxsi For This Useful Post: |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Well, it feels great so far, but I will report back in a week. I might adjust the cable on the shifter that changes the 1-2 and 5-6 feel. I usually release the adjusting tab, let the shifter find its equilibrium on the cable, and then secure the tab. I think this will make it even better. The throws are just right by the way. Not too long and not too short as to be notchy. I will keep the stock weight for now. I might try my trimmed weight later.
![]() | | #38 | ![]() |
![]() Join Date: Jul 2014
WOW, Torque likes it so it must be good! .... haha. Im just kidding Torque but I know you have hated 95% of the mods you have done to your speed3. Your review kind of reminds me of the old Life Cereal commercial. (Mikey hates everything) Except substitute "Speed3 mod" for "cereal" and "Torquerules" for "Mikey".
__________________ "This is your life. And it's ending one minute at a time." | |
![]() | | #39 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score I've never had a single issue with crunchy shifts or anything with my DM shift plate. Just click click click click every shift. |
| The Following 2 Users Say Thank You to neganox For This Useful Post: | InkedInspector (11-10-2014), Matt@DamondMotorsports (11-10-2014) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Had the dms plate on for about a week or two. Hands down way smoother than the cs plate I replaced. The cs plate left me with something to desire, binding up, rubbing cables, lock out at high rpm's. Definitely recommend.
| The Following 3 Users Say Thank You to macdiesel For This Useful Post: |
| Display Modes | |
| NEW!! JBR MAZDASPEED 3/6 Adjustable Short Shift Plates in Stock!! | JBR | JAMES BARONE RACING | 58 | 03-30-2015 01:06 PM |
| JBarone Short Shift vs J-speed short Shift | jallways | 2010 MS3 - Engine, Transmission & Driveline | 97 | 05-27-2011 11:33 AM |
