| Damond Motorsports Welcome to Damond Motorsports, home of Track Tested Driver Trusted performance products. We aim to specialize in reliability and power modifications, for the track and the street. Every product we offer has been put through many hours of both road course and street use, to insure excellent reliability and performance. |
![]() Join Date: Jan 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score Got it, install took about 1 hour. Shipoing was super fast ordered it Friday got here(ny) on Monday. Snapped one of the bolts that hold the bpv. So I haven't gotten to test it much. Just picked up new bpv bolts ill update once car is running again. Sent from my SPH-L710 using Tapatalk 4
__________________ 2011 Black Speed3 AP, AutoTech Internals, Cp-e dp (No cat), K&N Typhoon, HTP 3" inlet, H&R coilovers, JBR camber arms, JBR RMM Freeked |
| The Following User Says Thank You to thedoctor For This Useful Post: | Matt@DamondMotorsports (09-11-2013) |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
I just replaced my motor and put in a catless DP and internals - now I'm smoking like Cheech and Chong, even with idle at 950 and Rotella....
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM | |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score You're going to have to get one and test it yourself. Some people (like myself) got rid of the smoking with the use of a properly sized restrictor bolt and some people didn't. It seems to be a case-by-case fix. It's a relatively inexpensive fix and if it doesn't work for you, you can turn around and sell it...
__________________ ![]() [SIGPIC][/SIGPIC] |
| Not Ranked : 0 score so far so good. i did get a bit of smoke a few times, but it no longer smells like im burning thru a qt a day and aside from the 2 times that i seen a bit of smoke after that, its been good.
| The Following User Says Thank You to thedoctor For This Useful Post: | Matt@DamondMotorsports (02-26-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f661/stock-turbo-oil-restrictor-banjo-bolt-152336/ | ||||
| Zakman's Speed6 (previously Mz3) - Page 6 | This thread | Refback | 08-13-2013 01:09 PM | |
| Bnoon Banjo turbo restrictor bolt | tburton101 | MazdaSpeed 3/6 - Turbo Induction | 24 | 07-13-2009 10:06 AM |
