Like Tree14Likes
 Old 12-12-2014, 02:46 PM   #41
Name is longer than yours
Posts: 209   (View Stats)
Originally Posted by dagrimey1 View Post
Mine is not really an issue it just not as smooth as those Damn PU's.
I love the feeling of a smooth pu
RedDevil13 (12-12-2014)
 Old 12-12-2014, 02:51 PM   #42
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
I'll take a closer look at mine this weekend, but something is definitely giving, the play is noticeable. I also occasionally hear a cracking/clicking sound when shifting under the boot.
I too am feeling the rough 2nd gear shift, it sometimes causes me to grind because I am anticipating a quick & "smoother" shift. (driver mod.... of course )
Will we ever see a complete shifter for the 6? I'm not holding my breath, but I would without a doubt purchase one immediately if they became available.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
Matt@DamondMotorsports (12-12-2014)
 Old 12-12-2014, 03:03 PM   #43
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Regarding the MS6 FMIC, I have done quite a bit of workup on doing what I felt was a good one. I definitely prefer both hot/cold side pipes on the driver side with a top tank/bottom tank configuration as seen here. Custom crash bar. I think 2.25" hot side, 2.5" cold side with as few of couplers as possible. CPE had pretty good routing but that big aluminum tray that made you hack all of the air guides was totally dumb. The should have just don't a crash bar and moved everything up.
Don't make us hack up the front bumper/air guides, or at least at little as possible. We don't want high pressure air to go anywhere but through the FMIC/radiator. Some guys want a TR10, I would be very happy with a TR8 size intercooler (rated to 500hp) personally. That takes care of 90% of us.
To top it off, do an air diverter so all of the air that used to go to the TMIC can be directed into the radiator area.
I think piping + crashbar + diverter + piping - intercooler would be a fair price at $500-$600usd.
Dale's custom FMIC setup for MS6 - take 2
MINI H1 6.0 - CAR LED TAILS
The Following 7 Users Say Thank You to dale_gribble For This Useful Post:
Code Monkey (12-12-2014), ItsNox (12-17-2014), Matt@DamondMotorsports (12-12-2014), Micha (12-13-2014), ms6mil (12-12-2014), the public enemy (12-12-2014), WetzMS3 (01-15-2015)
 Old 12-12-2014, 04:01 PM   #44
I know my designs are largely a pipe dream but here are more ideas. Keep in mind I do not have a condenser or a purge solenoid valve line.
For road racing, I do not want to cover the whole radiator + I want hot and cold side pipes as short as possible for a quick throttle response.
Mount a vertical intercooler "vertically" (duh), the hot side is obvious. The cold side could either (1) go through the top with some fancy pigtail curve or (2) go through the bottom (obviously requires the end tank to be positioned appropriately).
This picture shows an ideal position of the two holes if we go with (1) above.
A variation is to have the cold and hot sides on the same side, which makes the hot side even shorter (pardon the intercooler "design").
I think this way we could have our cake and eat it too when it comes to lower BATs and fresh air flow to the radiator or at least part of it.
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
Awal (05-12-2015), dale_gribble (12-12-2014), SpeedRebirth (12-13-2014), Vansquish (03-20-2015), WetzMS3 (01-15-2015)
 Old 12-12-2014, 04:43 PM   #45
King Scumbag's Avatar
Posts: 2,384   (View Stats)
@SBMS316; please elaborate on the needs on the short shifter for our platform.
For one thing is the plastic guide that prevents you from going into reverse wears thin and give you that not so smooth shift to 2nd gear. If you own a 6 or any first Gen 1 3 I'm pretty sure you know that feeling
@dagrimey1; as much as I would love to give some insight and as much as I dislike a specific Vendor right now I'm gonna refrain. I'm sure @Matt@DamondMotorsports; will get plenty of good feedback on that from the rest of the community.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
Micha (12-13-2014), WetzMS3 (01-15-2015)
 Old 12-12-2014, 11:04 PM   #46
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
1. Please elaborate. Adjustability of what?
2. Do you see it flex mid shift, or after you've hit the gate? (I hope you're not driving and looking at your shifter at the same time)
3. Where are they wearing?
Adjustability of shifter height and throw length.
Both, it flexes when it hits the gate (the part that wears on all our shifters) and mid shift. I've missed second plenty of times.
My car doesn't have too much wear on its shifter but I saw one where the ball at the bottom of the shifter stalk was loose inside the area that holds it.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 12-16-2014, 12:09 PM   #47
igve2shtz's Avatar
Posts: 72   (View Stats)
igve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant future
With a thread title like this, I'll beat the dead horse ... +1 on TR8 FMIC option (crash bar/brackets/piping (or use CX piping). I'll be first to sign up ... even going as far as to upfront a down payment.
Yay for MS6 love.
2006 MS6 Velocity Red Mica
SP63 built motor - SP63 9.5:1 Pistons - Manley Rods - JBR TRU-3" intake - BNR S3 - ETS 3.25" TMIC - Cobb XLE BPV - SP63 IM Port n' Polish - JBR TB TIG - JBR IM TIG - 3 Bar PnP (RPM) MAP - Autotech HPFP Internals - cp-e SafeSeals - NGK Plugs - Streetlite Flywheel - ACT 6 Puck Clutch - GrimmSpeed EBC - BSD - cp-e Catted Downpipe - Magnaflow CBE - cp-e RDM - cp-e Motor Mount - BC Coilovers - 215/45/18 Kuhmo 4x All-Season - Cobb Accessport V2- Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter
igve2shtz is offline   Reply With Quote
The Following 2 Users Say Thank You to igve2shtz For This Useful Post:
acemanz (03-20-2015), Micha (12-17-2014)
 Old 12-29-2014, 04:32 PM   #48
Wondering if it is possible to come up with or adapt a "heavy duty" power steering cap that Maruha makes for the Miata.
 Old 12-30-2014, 10:55 AM   #49
Are you leaking fluid from the cap while tracking? The only time the PS reservoir spills a little fluid out of the cap, is probably close to 1G.
I have a solution for you... reservoir sock. You could even make your own. Here's a pic on my old 6, not the greatest pic, but you can see it, and it worked well. No more fluid on the belt at the track:
The Following 2 Users Say Thank You to Matt@DamondMotorsports For This Useful Post:
Code Monkey (12-30-2014), WetzMS3 (01-15-2015)
 Old 12-30-2014, 10:58 AM   #50
reservoir sock
That's what I've been using for a year now.
 Old 01-15-2015, 10:57 AM   #51
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
bump
08 cwp ms3
 Old 03-20-2015, 03:32 PM   #52
do you guys have a speed6 tow plates? I only saw them gen2 speed3's on your website
08 cwp ms3
 Old 03-20-2015, 10:56 PM   #53
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
still in for MS6 FMIC
acemanz is offline   Reply With Quote
The Following 5 Users Say Thank You to acemanz For This Useful Post:
DingoDave (11-13-2015), ESA (05-31-2015), ItsNox (05-11-2015), Mr. T (03-27-2015), wwpms6 (03-21-2015)
 Old 05-11-2015, 09:33 PM   #54
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Plumper bumper
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-12-2015, 08:56 AM   #55
ItsNox's Avatar
Posts: 3,076   (View Stats)
Whats that @Farhan@DM;? You're designing a FMIC for the speed6?!
I'll just keep wishin'
mustang-killer likes this.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
The Following 6 Users Say Thank You to ItsNox For This Useful Post:
bcmurphy87 (04-27-2016), BrianB6 (05-15-2015), ESA (05-15-2015), Raider (05-13-2015), twincitySPEED6 (05-17-2016), xfeejayx (05-13-2015)
Page generated in 0.35582 seconds with 31 queries
