| Stupid Little Cunt ![]() Join Date: May 2015
Rep Power: 0 ![]() Thanks: 0
Groaned at 35 Times in 19 Posts
(Thread Starter) | Not Ranked : 0 score Sent from my iPhone using Tapatalk I ordered the one for newer gen when I have the older gen . Sent from my iPhone using Tapatalk Last edited by Stansms3; 06-24-2015 at 08:11 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 3 Users Say NO Thank You to Stansms3 For This Un-useful Post: |
| Not Ranked : 0 score I have no idea what you are asking. BPV is the same. |
(Thread Starter) | Not Ranked : 0 score The part were the bov connects to Sent from my iPhone using Tapatalk No screw can go in that hole so I ordered the part but I ordered the one for the 2012 ms3 can it still fit mine it's called the vacuum hose Sent from my iPhone using Tapatalk Cant* Sent from my iPhone using Tapatalk Last edited by Stansms3; 06-24-2015 at 09:04 PM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score Sounds like a bolt is broken inside it. The cold pipe off the TMIC is the same for gen1 and pu. |
(Thread Starter) | Not Ranked : 0 score Yea the no bolt can go in that hole so now I have a boost leak cause theirs only one screw in . Next I ordered the part for the 2013 ms3 when I have the 2008 ms3 can the part that I ordered still fit? Sent from my iPhone using Tapatalk The parts were the bov connects to Sent from my iPhone using Tapatalk Last edited by Stansms3; 06-25-2015 at 06:42 AM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score Going to guess English is not your first language. And yes it will work. |
(Thread Starter) | Not Ranked : 0 score Thanjs Sent from my iPhone using Tapatalk |
![]() Join Date: Jun 2013 Location: Millersville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score pictures are worth a thousand poorly put together words. Just an FYI |
| The Following User Says Thank You to Bludypoo For This Useful Post: | Raider (06-25-2015) |
