Groans: 189
(Thread Starter) | Not Ranked : 0 score So far, I've been able to do basic testing for air ride control and have successfully tested my Arduino Uno and air ride logic separately, but I've not yet built them together and done a full test. I'll probably make a new thread for that specifically. For the project car, I'll have four RasPis for realtime video recording/compression and viewing (as they will replace the side mirrors; yes it's legal where I live) and minimum 5 Arduino/clones for air ride and misc control; four Teensy 2.0; one for each wheel for ride height control, plus maybe an IOIO Mint or equivalent to control the four Teensy and misc relays and whatnot (since it can hook up to the phone, I won't need a key to start it). Anyone else doing anything interesting with their cars electronics wise?
__________________ |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groaned at 16 Times in 7 Posts
| Not Ranked : 0 score I just found this thread by searching for "arduino" on google. ha! Sounds like a fun project! I'm wanting to build a methanol injection controller using Arduino, because for one I hate using a Hobbs switch because it is a mechanical component, and two because I've never touched an arduino board and I'm dying to. I have no experience with coding or programming, but I tend to pick up on things like this quickly.
__________________ '06 Mazdaspeed 6 |
| The Following 2 Users Say Thank You to timjs For This Useful Post: | Enki (12-31-2013), radioflyer (01-02-2014) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I'm actually considering doing just that using my Arduino Uno as a test bed, and finalizing the build using a Teensy because it's tiny like the name suggests, and low power. I'm wary of tying into the MAF sensor, but I think that's the best way to do it aside from maybe a boost sensor. I'm not sure what way I'll go but I'll figure it out eventually.
| The Following User Says Thank You to Enki For This Useful Post: | timjs (12-31-2013) |
| Not Ranked : 0 score I was thinking just using the MAP sensor's output as an input for the controller. Maybe ramp up meth with boost via a PWM output. Idk how much amperage the pump will pull though. Probably less than 10 amps. Basically, everything you can get in any of the meth controllers on the market, except 100x more awesome because DIY.
| The Following User Says Thank You to timjs For This Useful Post: | Enki (12-31-2013) |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score AEM pumps have a "protect with 15 amp slow blow fuse" label FWIW.
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score I just looked up some arduino methanol controller builds and that would be awesome. If only someone would make a kit... @Lex;
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following User Says Thank You to sidekick For This Useful Post: | timjs (01-01-2014) |
| Not Ranked : 0 score I looked them up too, couldn't find a project that someone actually finished, though. A kit would be nice, but Arduino is more of a prototyping platform. A company would make a working product with Arduino, then get some custom pcbs and a fancy enclosure and sell it for quite a bit.
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
| Neutral : +1 score
while (Voltage > X) //Where X is the threshold and voltage is the variable sensor input { digitalWrite(transistorPin, HIGH) } where the transistor pin is a basic circuit that will allow you to switch on the pump by grounding the GND from it via a transistor. Of course, you should write a function for this, where you call it via an If statement, and run it for as long as the while command is true. This is very basic, but I have extensive knowledge with the Arduino and overall programming, if you ever get stuck don't hesitate to give me a shout, I have a few lying around myself and wouldn't mind dedicating some time to helping out.
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned | |
| The Following User Says Thank You to Roddiy For This Useful Post: | sidekick (01-01-2014) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Oh, I already have very basic air ride control code for my Uno. I've got that much of it down, and probably won't run into any coding headaches unless there's some foible I don't know about. I'm more interested in how to set up a cascading MOSFET setup to allow variable speed pump control or introducing PWM to a couple solenoids for multiple nozzle staging.
Groans: 279
example: Oh and don't forget an awesome carbon fiber ricer panel with a basic form of Linux in a Raspberry PI, with dedicated GUI, allowing you to control everything...
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
Sent from my SAMSUNG-SGH-I747 using Tapatalk
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
Groans: 189
I was under the impression that FETs and MOSFETs are largely interchangeable terms now... It's just that there are a huge number of functional variants.
__________________ | ||
Groans: 279
an LED can be hooked up directly to the Arduino, try hooking up a 12v 1A+ pump to the Arduino... yo shit's gonna blow. I'm curious as to what amperage the pump is rated at under maximum load (ramping up the pressure) because that will affect what motor controller (IC) you'll have to use. Have some fun doing PWM control on a DC motor first, the circuitry is largerly similar if not exactly the same as you would use to control the pump. EDIT: I've used and have a couple of SN75441 ICs, but an L293d/L298 IC should work just as well, given the pump doesn't take more than 2A max as for the RPI... Yes the raspberry stock OS should do fine, but the program still has to be written ![]() Processing would be a very simple but quick way to get it done, since it's very similar to arduino language and very easy to communicate between the two.
Groans: 189
In fact, the PWM testing I did was not with a single LED, but with an LED matrix which required in excess of 9 volts to power *without* resistors, and was driven via one of these MOSFETs.
Groans: 279
In that case you're good, but I gotta wonder, what kind of resolution do you get using PWM through a logic level MOSFET? the full 0-1023 offered by the Arduino's analog pins or do you have to use the map function to reduce that a bit?
Groans: 189
The listed switching time is measured as less than 500 nanoseconds, so it should be viable for full resolution Arduino control. Edit: The threshold voltage is 2.5 volts so I think I might be overdriving it a bit; I should probably look into what the required full on voltage is vs threshold voltage.
| The Following User Says Thank You to Enki For This Useful Post: | Roddiy (01-02-2014) |
Groans: 279
IIRC reading the comments the full on voltage is 5V+
Groans: 189
(Thread Starter) | Not Ranked : 0 score Looking at the datasheets, less than 3 volts is needed to supply 10 amps, with about 7 volts needed to flow 100 amps. 5v should be enough to supply full rated amperage with diminishing returns starting in below 4v.
| The Following User Says Thank You to Lex For This Useful Post: | Enki (01-03-2014) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score It does have a couple things going for it though: availability, price, and ease of use. Once you have working code, even if you burn up one of them, you can get another for under $20 (teensy) and re-load the code.
Groans: 47
| Not Ranked : 0 score Hey, if you're making a legit meth controller, I don't even care what it's made with. Lol. I'm sure it will be much better than some of the current offerings. I like the idea of being able to control the meth with more than an on/off switch.
| The Following User Says Thank You to sidekick For This Useful Post: | Enki (01-03-2014) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I can easily rock some open source community code, but I don't have the hardware to play with yet (meth parts) to actually make something.
| The Following User Says Thank You to Enki For This Useful Post: | sidekick (01-04-2014) |
Groans: 433
| Not Ranked : 0 score curious what you're using camera wise to go with the raspi's for video. I picked up a raspi and no zero coding but I'd like to set up forward/rearward video capability.
![]() | | #24 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I'm going to use Raspi cameras. I'll have at minimum four Raspis on board configured to automatically boot to console and start the camera app (that comes with Raspbian). The command line for that looks like this:
![]() | | #25 | ![]() |
Groans: 433
| Not Ranked : 0 score well, I have a Pi with the camera, I just wasn't under the impression that the quality will be good enough for use in that manner.
![]() | | #26 | ![]() |
Groans: 189
Also, keep in mind this is compressed compared to what I actually saw on the LCD (which was beautiful and very much real time).
__________________ | ||||
![]() | | #27 | ![]() |
Groans: 433
| Not Ranked : 0 score Video quality is great.......................but that scenery is OOOOGLY! haha.
![]() | | #28 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Yeah, well, desert. The video doesn't do justice what I was able to make out on the screen, and the screen isn't even 720p.
| The Following User Says Thank You to Enki For This Useful Post: | Chimmike (01-08-2014) |
![]() | | #29 | ![]() |
Groans: 433
| Not Ranked : 0 score Wish I was skilled enough to do some of this shit.
![]() | | #30 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score To be fair, I didn't know how to do ANY of this shit when I started. All it really takes is determination and Google.
![]() | | #31 | ![]() |
Groans: 433
| Not Ranked : 0 score you have a programming background?
![]() | | #32 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Nope. I've learned what I know on my own. The only classes/certifications I have are MCP on Win NT4/2kpro and an A+ cert (which as we all know is a joke).
![]() | | #33 | ![]() |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Here is the progressive water\meth controller i made for my devils own kit - arduino pro mini 5V - freescale semi MXP series pressure sensor - logic level power mosfets (IRL540 with heatsink) for solenoid and pump, work great because of their relatively low duty cycle - RGB led output (for system status) mounted in a-pillar - float switch input (I have a coolingmist tank that had a float switch installed) - Aux analog input. I have a labonte motorsports flow controller that outputs 0-5v according to flow. I used this as another alarm condition, indication of bad pump or clogged nozzle my code is laughable, but it works. If other people here know how to program, I will strip out my progressive control part and just make a file of helper functions to read\write the ports, set LED color, etc etc.. that way it can be duplicated easily. I'll throw it on github if there is any interest in contributing In the attached pictures, I use a sparkfun FTDI board for debug. Thats what that crazy header thing i soldered on was for. I used 7809 voltage regulator to the RAW pin on arduino, which uses its onboard 5v LDO reg. Peripherals are then run off the VCC pin. I find multiple regulators smooth out cruddy automotive DC power. - to do: automatically pull timing when error condition is present with controller. Perhaps this is a relay output, or intercepting and spoofing crank position sensor. - add bluetooth so it integrates easier with android - i started laying out a custom board, possibly finish it and upload to OSHPark to make a standardized open source water meth controller |
![]() | | #34 | ![]() |
| Not Ranked : 0 score That is just fantastic!
| Renesas aims to hike microcontroller share with TSMC deal | Haltech | Automotive News | 0 | 06-19-2012 10:00 AM |
| A few stories I never got around to posting. | Mr Moose | Street Racing Stories ( Bench Racing ) | 0 | 04-11-2010 01:40 AM |
