| FREEKTUNE Freektune is the leader in Mazdaspeed tuning. Having tuned over 300 individual Mazdaspeeds around the world, we can deliver the highest quality of engine tuning for your vehicle. We specialize in driveability, engine performance, engine building/repair, and most of all customer service. |
![]() Join Date: Apr 2015 Location: Santa Rosa, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 153
(Thread Starter) | Not Ranked : 0 score I have an accessport in which I took a log in 4th gear from 3k RPM's to as high as I could on the freeways around here, I think it topped off around 5500-6k with the pedal completely depressed but clearly to the logs it doesn't show 74-76% throttle position. Someone has told me it could be the tune (running the poop accessport stage 0 map due to insufficient mods), or a boost leak somewhere. Would it be beneficial for me to get an actual tune done through freektune or another reputable tuning company to run and see if it is indeed the tune that's causing the problem?? My biggest dilemma is that I don't have an air compressor nor know where I can use one in hopes to locate said boost leak/loose clamp/etc. Or should I just wait until I install my inlet and intake, hopefully assure all the clamps are connected fully and then get a tune made? |
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
Throttle position will only go to around 75 which is maxed
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway | |
| The Following 2 Users Say Thank You to Justin@Freektune For This Useful Post: | btstarcher (11-23-2015), xorphanx (11-20-2015) |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
| Not Ranked : 0 score +1 to that ^ pay this man to fix your "problem" and go fast.
__________________ https://www.youtube.com/user/JustinBieberVEVO |
| The Following 4 Users Say Thank You to Gr8Speed For This Useful Post: |
This was from another thread, I just started one here to stop spamming a guys issue with my own :| trying to be courteous... I haven't figured out how to tell if it's running rich/lean or mainly what to look for in these datalogs. People say provide them and I make it happen... Last edited by xorphanx; 11-20-2015 at 02:01 PM. Reason: MSF Database - Automerged Doublepost | |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
In your case the AFRs are deep into the 9s and under no normal circumstances this should happen no matter the tune, gas type (91 or 93/94), not to say at those boost levels which are less than what the stock tune would target
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | jabeel00 (11-23-2015) |
(Thread Starter) | Not Ranked : 0 score That makes sense. I guess not ever seeing datalogs would be a key player in this. Well I got my intake/inlet scheduled for the 24th as a delivery date, we'll see how things go during the install if I can find any possible leaks in that time |
(Thread Starter) | Not Ranked : 0 score So i'm pretty convinced by now that I've checked all my fittings. The only thing I haven't done is a legit boost leak test due to not having the required tools for it. Someone did suggest taking apart my HPFP again and looking at the flap inside controlled by the cam? (i'm assuming). But i'm pretty sure that it's running some rich due to upgraded internals but not upgraded intake (which will happen this weekend). so ONCE I get that done i'll be buying a tune from FREEKTUNE to make sure it's all good with air and fuel, and that it has a proper tune on it. If problems still persist there, then i'll start going into looking at the mechanical aspects of things.... As easy as that internals install is, I would rather not do it twice lol. |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score A quick test you can do to help figure out if you have a leak and consequently where that leak may be located is to look at your LTFTs. If you have a leak, your LTFTs will be wonky ie. pretty high...positive will indicate vacuum leak and negative would indicate a leak somewhere between the throttle body and turbo.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
ECU will correct your fuel trims when going part throttle, so you look at your STFT/LTFT... | |
| The Following User Says Thank You to frothy For This Useful Post: | xorphanx (11-23-2015) |
"LTFT's show adjustments being done to your fueling. + means it's adding fuel, and - means it's pulling fuel. + or - 10 is within normal parameters, anything higher means you have a boost leak or pulling unmetered air." I just found this which seems super informational, I will be monitoring my LTFT on my drive home today to see how the levels look. Last edited by xorphanx; 11-23-2015 at 11:17 AM. Reason: MSF Database - Automerged Doublepost | |
Groans: 111
If for you is easier to pull the pump than making a boost leak test then the problem is bigger than we thought,
| The Following User Says Thank You to mituc For This Useful Post: | robbspeed (11-23-2015) |
(Thread Starter) | Not Ranked : 0 score I just need to get to home depot to buy some pvc caps to block the hoses and get ahold of an air compressor.. Sometimes I wish I had a garage... >.> |
![]() Join Date: Sep 2015 Location: Brick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,356
Groans: 50
How-To NATOR A Boost Leak Tester for $15
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. | |
For casual driving and idling, monitor fuel trims. When going WOT, monitor AFR. Keep in mind, there's also a learning period for long term fuel trims. So if you load a new map or disconnect the battery to reset the ECU, your LTFTs will be "0" for a period... Read through this to get a basic understanding of some of the parameters: Ultimate Guide to Parameter Monitoring? Another good link: Understanding Fuel Trims & Using Them To Detect Leaks | |
(Thread Starter) | Not Ranked : 0 score Screw it i'm leaving work early to go get the stuff and do the boost leak test today. I'll report any findings I have. |
When i disconnect my battery and reset the ECU do i need to remap my ECU? as in reflash the tune? The only time I flashed it was after I did the HPFP internals because i got my AP the same day. | |
![]() Join Date: Mar 2015 Location: Acworth, Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
No you do not. Sent from my doucing phone.
__________________ MilTuned! ![]() | |
| Not Ranked : 0 score |
(Thread Starter) | Not Ranked : 0 score Haha I told you it was gonna be hella dumb!! But always good to clarify, Never messed with an ECU before so i'd rather be safe than sorry. |
(Thread Starter) | Not Ranked : 0 score So i did my boost leak test, came up with nothing. took it to a shop down the road, they said that there's a broken transmission bearing, and possibly need a new clutch. Would I still be able to factor this under my dealership warranty even after changing my motormounts? |
(Thread Starter) | Not Ranked : 0 score UPDATE : during shop inspection we found the following..... noise from transmission input shaft bearing, possible broken bearing? dirty MAF sensor which I haven't touched since i bought the car. Smoke test on the intake manifold, smoke coming from EGR valve assembly. no boost leak... My question now is when I replaced my TMM, could that have possibly done damage to the bearing??? I don't see how this is possible, but you never know.... Luckily everything is still covered under warranty from the dealership and I have an appointment scheduled for Dec 2nd. By replacing the motormounts/swaybars would that have any impact on why one of these items may not be covered?? |
Groans: 50
| The Following User Says Thank You to robbspeed For This Useful Post: | jabeel00 (11-23-2015) |
![]() | | #24 | ![]() |
According to the FT searching I've done between -10 to +10 are "normal ranges" so i'm not too worried about it. I know i'm not expecting it now to read 0 unless i'm WOT. This whole ordeal has been quite the learning process for sure. | |
| The Following User Says Thank You to xorphanx For This Useful Post: | robbspeed (11-24-2015) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Corksport Stage II SRI has just arrived with the rear stability bar and hood hydraulic lifts! Time to get to work! Unfortunately the SRI will have to wait for install once ma car gets back from the dealership on Dec 2nd to locate any leaks in the boost system... (hopefully not to find any and it just needing the more airflow and tune done!) Christmas is comin early! AND IT'S NOT EVEN BLACK FRIDAY DEALS YET!!! AND GEN2 airboxes will be coming back soon! |
![]() | | #26 | ![]() |
Groans: 50
| Not Ranked : 0 score Good luck. Hope everything works out.
![]() | | #27 | ![]() |
![]() Join Date: Jul 2014 Location: Saskatoon, SK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score I know that this is a little late, but I will post it here anyways. This is a set of vdynos depicting the difference between a boost leak and a tune pulling boost. All of these runs were done on the same map. First, notice how the blue and green pulls make very similar hp/tq, but the red line is WAY down on the graph. Second, The blue boost line is exactly 2 psi below the green pull for the whole run, while the red line does not follow the boost curve, instead it plateued at 19.8 psi and held it. Third, this is a 10gph meth map (I'm not sure if a gas map would do the same thing) but the red line goes really rich near redline with no knock. I assume this is because the MAF is reading way more airflow than what actually made it into the engine and it was unable to correct it. The blue line goes rich because I started to have pretty heavy KR in those sections due to winter gas (I swapped to a less aggressive map now, which alleviated the KR). The boost leak I had was pretty massive, the cold pipe going onto the throttle body was VERY loose. I removed it without undoing the clamp. Another thing I noticed in these datalogs, if you have a boost leak you will command the same wgdc but get less boost, if it's the tune pulling boost you will be getting less wgdc than before (which makes sense).
__________________ 2010 BM - FREEKTUNED - BNRS3 Last edited by spl; 11-26-2015 at 04:32 PM. Reason: embedded image is not linking properly, fixed finally |
![]() | | #28 | ![]() |
![]() Join Date: Nov 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Any updates xorphanx? |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oh yeah, lots has been done up until now. When i went to swap out the Stage II SRI, the stock TIP ring clamp wasn't even tight... the thing slid right off.. After installing the new intake I had no issue, I also did get the CS airbox but I haven't noticed much of a difference. Once we get out of the winter months i'll be going to a CAI, also looking into the CS turbo which i'll install my bar + harness, and ebcs with along with another retune.
__________________ 2013 MS3 Velocity Red with Techpackage |
| Boost leak testing, possibly Wastegate/Actuator leak | AgentWh0 | 2010 MS3 - Troubleshoot/Diagnostics | 0 | 08-04-2015 12:29 PM |
| Not hitting boost targets, not boost leak | ADHDAdditiv | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-18-2014 02:18 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Vacuum leak, but no boost leak? | vbt101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 23 | 04-18-2010 01:06 PM |
