  • 1 Post By Wildcard
  • 1 Post By 865ms3
 Old 03-26-2014, 10:53 PM   #1
Wildcard's Avatar
Posts: 595   (View Stats)
Wildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the world
Default Freektuned E85 K04
I posted this elsewhere recently, but it is quite relevant to be posted here as well. For anyone considering Justin to perform your tune, this is just more proof to DO IT!
My current goals are to keep the K04 and attain 325whp in the easiest and most financially sound way possible. Things/Changes I will be considering this spring include: Going back to an FMIC, upgrading TIP/SRI to 3", and upgrading/changing other minor aspects of my combo
And of course Justin will be doing my tuning.
donjohnk likes this.
08 Mazdaspeed 3 GT
COBB APv2 // TR8 FMIC // CP-E Full Catted Exhaust // HTP 3" // Relentless Customs IM // JBR: TB TIG, Shifter Bushings, SSP // KMD's // Grimmspeed 3-Port // Damond RMM // Autolite XP5263's
Wildcard is offline   Reply With Quote
The Following User Says Thank You to Wildcard For This Useful Post:
Hush (03-27-2014)
 Old 03-26-2014, 11:14 PM   #2
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
Nice flat lines there.
Can you explain the reasoning for going back to the stock TMIC and stock heat range plugs? I'm not challenging, just curious
2008 Gen1 MS3
Self tuned on E85
 Old 03-26-2014, 11:22 PM   #3
spd6demon's Avatar
Posts: 164   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
Nice numbers! Awesome how your k04 kept over 18psi by redline. Mine tapered off to 15psi when I had it.
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
 Old 03-26-2014, 11:34 PM   #4
Wildcard's Avatar
Even if you were challanging, no biggie. Short answer: Educating myself on the platform. Long answer: To reach my goals, which are quite possible on a K04 with methanol and ethanol, I'm quite sure a stock TMIC will suffice.
That being said, I am going back to stock TMIC tomorrow and run a few logs to see what has been lost. If I don't poop my pants due to a massive power loss, I will be selling the CS TMIC and using those funds towards a proper WMI kit.
Then from there I will be researching pre vs post turbo meth.
As stated earlier, I'm essentially trying to reach my goals with the least power mods possible. Kind of for fun.
If it wasn't such a hassle, I'd even consider going back to a stock cat-back. Boy do I wish I waited to really learn the platfom before just spending $$$$.
I haven't studied/seen enough of other people's logs to notice and I don't recall Justin pointing it out. Is this rare compared to most with similar mods?
08 Mazdaspeed 3 GT
Last edited by Wildcard; 03-26-2014 at 11:35 PM. Reason: MSF Database - Automerged Doublepost
montyspeed388 (03-27-2014)
 Old 03-27-2014, 12:02 AM   #5
spd6demon's Avatar
I've only seen a handfull of k04 tunes from NATOR AR, but most of them tapered from 20psi to 16psi by redline. It may have to do with the tuning. Cause all the ones I've seen had been tuned by Lex from Stratified.
 Old 03-27-2014, 12:16 AM   #6
Wildcard's Avatar
Could also be differences in air? I ran this log in 26* weather. As we know, cold air is more dense.
08 Mazdaspeed 3 GT
 Old 03-27-2014, 12:59 AM   #7
spd6demon's Avatar
I'm not too sure..I did my tune during the winter last year while the temps were in the 30's. Maybe its just cause you're k04 is that badass lol.
 Old 03-27-2014, 01:29 AM   #8
Wildcard's Avatar
For being an 80k mile (to my knowledge) turbo, it doesn't smoke or burn through oil, so maybe you're right! Haha.
08 Mazdaspeed 3 GT
spd6demon (03-27-2014)
 Old 03-27-2014, 02:05 AM   #9
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Connect your stock EBCS to a tee in the BPV line instead of having it connected directly to the compressor housing. That will get you 18 PSI, maybe higher at 6k.
It's also going to put more strain on your turbo, so be warned.
ItsNox (03-27-2014), spd6demon (03-27-2014)
 Old 03-27-2014, 03:30 PM   #10
squilliam's Avatar
Posts: 266   (View Stats)
squilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the worldsquilliam is the leader of the world
are you running 100% e85 or a mix?
2009 CWP MS3: CP-E FMIC / CP-E RMM / Cobb SRI / Cobb TIP / Cobb AP V3/ HKS BOV / PTP HPFP Internals / UR V1 Catted DP / UR Racepipe / Cobb SS Catback Exhaust / Swift Spec-R Lowering Springs w/Koni Yellow
squilliam is offline   Reply With Quote
 Old 03-27-2014, 03:41 PM   #11
Wildcard's Avatar
That log and VD was on 50% E85.
I gain ~20whp/20wtq going from the 93 to 50% E85 map.
08 Mazdaspeed 3 GT
squilliam (03-27-2014)
 Old 03-27-2014, 03:44 PM   #12
865ms3's Avatar
Posts: 2,602   (View Stats)
i loved my 50/50 e85 k04 tune from @Justin@Freektune;
the car put down 330/375 on the dyno. i ALMOST....miss it
Justin@Freektune likes this.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
The Following 3 Users Say Thank You to 865ms3 For This Useful Post:
Justin@Freektune (03-28-2014), Micha (04-17-2014), Wildcard (03-28-2014)
 Old 03-27-2014, 04:10 PM   #13
Wildcard's Avatar
Those are essentially the exact K04 numbers that I am looking for. Might have to study your signature a little bit for ideas.
08 Mazdaspeed 3 GT
865ms3 (03-27-2014)
 Old 03-27-2014, 11:09 PM   #14
Lalangalang's Avatar
Posts: 214   (View Stats)
Lalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond reputeLalangalang has a reputation beyond repute
Im on a ko4 right now on 50/50 e85 mix freektuned and will be dynod this weekend. I dont have many mods either so I can update this weekend If your interested.
Peformance Mods
Gt3076r, Cobb AP, Cobb EBCS, Cobb piping, Treadstones tr8L, Ultimate racing crash bar, Hks ssqv in recirc, autotech HPFP Internals, HTP 3.5 intake/tih, Cpe turboback system, Jbr heavy knob, Jbr 88 rmm, Jbr shifter bushings, Jbr rsb, Jbr occ, Swift springs, Ebc redstuff
Exterior Mods
Yellow hella fogs, Red out tailights, Jbr V2 mudflaps,Fds or Evo X enkeis, Nator Tn/Ky Stickers!
Lalangalang is offline   Reply With Quote
The Following 2 Users Say Thank You to Lalangalang For This Useful Post:
865ms3 (03-28-2014), Wildcard (03-28-2014)
 Old 03-28-2014, 12:23 AM   #15
Wildcard's Avatar
Absolutely update. Have you run any Virtual Dyno logs? Always interested to see how close VD is to a "real" dyno.
08 Mazdaspeed 3 GT
 Old 03-28-2014, 06:32 AM   #16
Here is a vd on the same stretch of road I always log on. 4th gear before I put my Fmic on but it was super cold out.
File Type: jpeg 145238d1390540481-finally-freeked-freektune-50-50.jpeg (70.5 KB, 330 views)
Peformance Mods
Exterior Mods
 Old 03-29-2014, 12:12 PM   #17
My results first run had a slight boost leak fixed after.
Peformance Mods
Exterior Mods
865ms3 (03-29-2014), BigBoostMS3 (03-29-2014)
 Old 03-29-2014, 01:29 PM   #18
Wildcard's Avatar
Happy with those results?
08 Mazdaspeed 3 GT
 Old 03-29-2014, 01:34 PM   #19
Heck yeah. Still have to do downpipe and port my intake manifold.
Peformance Mods
Exterior Mods
 Old 03-29-2014, 01:51 PM   #20
Wildcard's Avatar
Damn! I didn't even notice that! I'm jealous as hell!
08 Mazdaspeed 3 GT
 Old 04-09-2014, 11:38 AM   #21
King Scumbag's Avatar
Posts: 2,384   (View Stats)
I get so excite when i wait for freekvisions to come back!
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 04-16-2014, 10:16 PM   #22
Shayne-ms3's Avatar
Posts: 71   (View Stats)
Shayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond reputeShayne-ms3 has a reputation beyond repute
Hoping for the same results as well! i've been on the base map for 50/50! I can't for new revisions! FREEK FTW!!!
1. 2009 CWP SPORT Mazdaspeed3 Corksport:SRI/TIP, SSP,TP. COBB: AP FREEKTUNE IN PROGRESS EBAY:CATLESS DP CORKSPORT:CBE BILSTEINS: B8 SWIFT SPEC R .RPF1's 18x9.5 et38 ROTA GRIDS 18X9.5 et38 HANKOOK V12's 235/40/18
2. 2009 CWP GT Mazdaspeed3 CPE SRI/TIP, COBB:AP JBR:RMM
Shayne-ms3 is offline   Reply With Quote
 Old 04-17-2014, 12:08 AM   #23
Wildcard's Avatar
You're in good hands for sure.
08 Mazdaspeed 3 GT
Shayne-ms3 (04-17-2014)
 Old 04-17-2014, 01:06 AM   #24
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
If you go back to the stock TMIC, you're not going to be able to hold as much boost pressure, especially at higher RPM. It does not cool as efficiently and has more pressure drop than the CS TMIC. While the meth would help with the cooling, you're still going to be working the turbo harder to reach boost targets and you may not be able to reach them in the top end before maxing out WGDC.
 Old 04-17-2014, 02:47 AM   #25
Micha's Avatar
Posts: 3,436   (View Stats)
You go through more tuners than I do. Jesus.
I am slow again.
I modded it a little.
 Old 04-17-2014, 10:40 AM   #26
Shayne-ms3's Avatar
I believe it! My 91 freektune is best tune so far!
 Old 04-17-2014, 10:54 AM   #27
Shayne-ms3's Avatar
I wanted a 50/50 map, but no one wanted to tune me for that. Others took very long respond. Also speaking with some of my friends tune by Justin they have nothing ,but positive feedback. He has great customer service , his tune delivers, he explains everything for you. Over the past weeks, I've gotten nothing but the best experience. He gets back to you very quickly and his communication is on point. Justin being a master tech is plus. I trust him with my car. FREEKTUNE is my tune!!
Freektuned Focus ST Dyno BigJimMs3 Ford Focus ST Ecoboost - General Discussion 13 03-31-2014 11:44 AM
Freektuned E85 PPD369Speed3 2010 MS3 - Dyno Sheets/Discussions 10 09-12-2013 05:34 PM
Freektuned, car running rich at wot PPD369Speed3 2010 MS3 - ECU Computer Tuning 13 07-26-2013 10:29 PM
Got freektuned Code Monkey MazdaSpeed 3/6 - Dyno Sheets/Discussions 8 08-18-2012 08:27 PM
Page generated in 0.46083 seconds with 31 queries
