Go Back   Mazdaspeed Forums > Mazdaspeed Forums Sponsors > FJ Performance
FJ Performance FJ Performance is dedicated to serving the community in the best way possible. We carry everything from OEM mazda parts to built long blocks. We also have our own product line FJBuilt. We have been in the mazda game for several years now and have a great understanding of the mazdaspeed platform as well as a few others. If you have any other questions about who we are or what we do please ask.
  • 1 Post By Matt@FJPerformance
 Old 07-15-2015, 09:55 AM   #1
Matt@FJPerformance's Avatar
Posts: 103   (View Stats)
Matt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the world
Default Our install process and how we take care of your car
A lot of customers ask what we do different when installing their motor from other shops.
Every FJBuilt motor install goes through the same process and we take pictures and videos for our customers along the way. Call it overkill, but this is our process, we want to make sure you're getting the most out of your build.
We turn the car over let it run and get up to operating temperature and check for leaks. After the car has ran for 20-30 mins. Up in the air it goes and let's get that oil out, we inspect the oil and make sure everything is kosher. 90% of all engine failures can be prevented when checking the oil after start up.
Assuming everything is good, time for fresh oil. At this point we fire the car back up and idle logs over to the tuner! Once they check out everything, time for the street! We drive and put between 250-300 miles of varying rpms staying out of boost. Then you guessed it back to he shop! Drain the oil! Check again! Make sure everything is great again! Everything checks out, then boom new logs to the tuner! Tuner checks again. If logs are good, it's time to bring a little boost in.
Back to the street for another 400-500 miles with light boost(typically never more than wg pressure). During this process we send multiple logs back and fourth with the tuner checking drivability and making sure the car performs the way it should. We always obey local laws on the street, we have a dyno for bringing the power in. After the miles have been put on you guessed it! Drain the oil again. Check everything out, if it all checks out its Time for power!!!(note on higher hp builds at this point we drop the oil pan and inspect the bearings, can never be to safe. Especially when you're about to put that amount of power through your block)
Now when we are dyno tuning I assure you every precaution is taking when doing pulls. Every aspect of your car is looked at by us and the tuner to ensure you get the best possible product.
Lastly we get a video of your car on our in house dyno and print a few dyno graphs(you know one for the wallet, office, fireplace, fridge, to hand out to everyone you see,etc)
Next step! Fresh oil change, last inspection, and fresh plugs!
Now it's time for pick up! This may seem like a lot for a basic build,let alone a full build. Our view is you're spending your hard earned money, you deserve a top notch product and service!
Feel free to message us about any build questions!
Robitaille06 likes this.
Matt@FJPerformance is offline   Reply With Quote
The Following 16 Users Say Thank You to Matt@FJPerformance For This Useful Post:
Awal (07-31-2015), g00s3y (07-16-2015), JgamB (07-15-2015), Justin@Freektune (07-15-2015), KiwiFlavor (12-08-2015), Koke382 (07-15-2015), Mauro_Penguin (07-16-2015), MD1032 (07-15-2015), Revmatch (11-25-2015), RhoadBlock (07-15-2015), Snyeed (07-15-2015), Thepedigree13 (07-15-2015), WAMBUSHHHH! (07-15-2015), WetzMS3 (07-15-2015), wwpms6 (07-16-2015), XxSmarTz (07-15-2015)
 Old 07-15-2015, 11:59 AM   #2
nindoja's Avatar
Posts: 2,395   (View Stats)
For those of us that bought a built block and installed it ourselves, is this the recommended oil change interval?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
The Following 2 Users Say Thank You to nindoja For This Useful Post:
Koke382 (07-15-2015), Matt@FJPerformance (07-15-2015)
 Old 07-15-2015, 12:54 PM   #3
Normally we tell a customer to follow the same interval that we use in the shop. Again it's better safe than sorry. But normally when we ship a block out we try to work it out with he customer and their tuner to there specific needs
The Following User Says Thank You to Matt@FJPerformance For This Useful Post:
nindoja (07-15-2015)
 Old 07-15-2015, 01:16 PM   #4
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
what additional costs come about when you have the whole car to play with vs a short block? Obviously the labor involved taking out/putting in the build block. Anything else?
Mods: stock
 Old 07-15-2015, 01:21 PM   #5
Oh we only charge fuel and fluids for the additional break in. It's part of the process
faeker likes this.
MD1032 (07-15-2015)
Water Process CF Radar_This Mazdaspeed3/6 General Discussion 15 06-14-2011 05:19 PM
Will be in here to take care of you... ptperformance Mazdaspeed3/6 General Discussion 4 02-01-2010 11:18 AM
Page generated in 0.27095 seconds with 22 queries
