Go Back   Mazdaspeed Forums > 2016 MSF Drags > Event Discussions
Like Tree87Likes
 Old 01-26-2016, 08:48 AM   #41
Simply and effective. I like it.
Justin@Freektune (01-26-2016), Realgib3 (01-26-2016)
 Old 01-26-2016, 09:03 AM   #42
Realgib3's Avatar
Posts: 2,443   (View Stats)
Also as for elevation correction. I'm all for it, but I think we'd have to figure out a good way to skew the correction only for the back half of the track. The front half, especially for the 3's, is where all the time is made up, and that's the area that doesn't need any correction for elevation.
Again, I'm not sure a good way to do it, but I can understand the desire to have some correction.
Easter Bunny (01-26-2016)
 Old 01-26-2016, 09:18 AM   #43
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I like those rules too. I also like the idea of the CF for the back stretch. I was never against an elevation CF, I just want it to be fair.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 01-26-2016, 10:07 AM   #44
LumberJack's Avatar
Groans: 57
The Buschur Shootout is now in its 24th year and is extremely successful. I have been going for a loooong time and I personally think a tweaked version of their class setup would work really well for us. Most of this is just copy/pasted from this years class rules, but I'm obviously changing the platform names. I'm also removing any tire type/size requirements because A) We don't have a lot of options that fit anyway and B) FWD needs slicks, so I'm not about to limit anything to DR's.
-STOCK TURBO-(ST)
-Any FWD/AWD- DISI MZR powered 3/6
-Car must retain stock appearing exhaust manifold.
-Turbo must use the stock bolt pattern from the exhaust manifold/header to the turbine housing and be located in the stock location.
-Turbo must retain STOCK compressor housing. This means bone stock turbo, S1, billet wheel upgraded k04's, etc. Nothing larger.
-External dumps are not permitted.
- Full exhaust exiting the rear of the vehicle is required.
-FMIC, intercooler plumbing, turbo inlet with air filter, small battery kits are all OK for this class.
-Two front seats, front door panels, full factory dash, center console and glove box door required.
-No Lexan.
-STOCK APPEARING TURBO-(SAT)
-Car may use any stock flanged exhaust manifold
-Turbo can have modified compressor housing. This means S3/4, CS, and ATP turbos.
-External dumps are permitted.
-No Lexan.
-QUICK STREET- (QS)
- Any exhaust manifold may be used
-OEM front and rear style/location suspension. Springs/coil overs/sway bars/control arms aftermarket are permitted.
-Exhaust may exit anywhere.
-Wastegates may exit anywhere.
-No Lexan.
Some things to note:
-No turbo size restriction for QS class. There's a reason nobody runs anything bigger than a 64mm on these cars. You wanna throw a Super 99 on there and think it'll make you faster down the 1320, be my guest.
-No fuel restriction for any class. We're DI, meth/aux fuel should be allowed for anyone who wants to use it.
-No exact weight requirements. Most aren't serious enough to get their car weighed and good luck getting people to weigh their cars at tech before a race. The interior rules for all classes will allow enough weight reduction to make a difference, but require enough interior kept to make it fair across the board.
-If you are the person complaining because a 58mm, non-stock flanged turbo is included with the "big boys" (cause 62mm is so huge right? lol) then guess what, go swap to a 60 or 62mm turbo if you think that'll make you more competitive in the class. A 62mm size turbo is still insanely streetable (As you can easily see in @LumberJack; recent TQ curve), so no, upgrading to that size will not make you immediately a full race car.
One of the most interesting parts of the Shootout is the fact that people literally form their builds, choose their parts, etc, around these classes. I think instead of adding any more classes to appease the "tweeners", just use this structure to force some people to make some slight build changes. That's what makes it interesting.
Anyway, those are just my thoughts, as someone who's seen a similar setup work extremely well for another import community.
Love it Mark, love the classes and that fits 95% of people right into something.
The only thing I'm standing firm on is the ET correction for altitude, and here's why.
1) You don't go to an event that's at altitude and get a corrected ET at the end of the pass, you ran what you ran.
2) You have the same capability of extra fueling of anyone at sea level. ( Hell, injectors get bigger at altitude so technically you have more fuel than someone at sea level with the same fuel system)
3) Those people that get killer air and DA like the east coast guys can get ( -1000DA etc ) you're telling me you're gonna correct there time slips to a slower time? No one is going to be okay with that.
4) Just to put it into light what type of corrections we are gonna be talking about.....
EXAMPLE: We will use Rob since he lives in the damn sky lol.... He runs a 10.5@140 and has a DA of 8k ft... You're going to be okay with correcting his run to a 10.06@145? I'm not trying to bash this, but that's a huge correction.....
Just my 2 cents
Realgib3 and Justin@Freektune like this.
10.36@148 Fastest Gen 2
The Following 5 Users Say Thank You to LumberJack For This Useful Post:
Easter Bunny (01-26-2016), Justin@Freektune (01-26-2016), Realgib3 (01-26-2016), tfusch4 (02-12-2016), WetzMS3 (01-26-2016)
 Old 01-26-2016, 10:15 AM   #45
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Just my 2 cents
the only thing I have an issue with Is this "1) You don't go to an event that's at altitude and get a corrected ET at the end of the pass, you ran what you ran."
Not everyone has the luxury of being at lower altitude. Shit if I wasent in the military I wouldn't be a mile high, since this "event" is basically taking place at everyone's local track, something needs to be done for the individuals at altitude. For me, I don't think it would be that much of a difference, were talking maybe .1 or .2 tenths, but for stock turbo/smaller turbo applications they take the largest hit.
I mean even look at our set ups compared to each other, you're making 100hp more uncorrected when you're on all of it and our builds are very similar besides turbos and head set ups.
To make the event as even as possible you would have to give the guys at altitude some type of break.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-26-2016, 10:22 AM   #46
LumberJack's Avatar
Groans: 57
You're also having issues holding boost up top to redline, I'm not... If you could hold your mid range boost to redline you'd be making well into the 900s corrected and probably well into the 800s uncorrected.
I didn't pull my corrected #s from just anywhere....
I used an ET correction calculator for a specific time and mph and DA for an example... Let's also note, you're going to penalize guys with good air quality and tell them they have to correct to a slower pass?
PapaSmurf (01-26-2016)
 Old 01-26-2016, 10:30 AM   #47
PapaSmurf's Avatar
I used an ET correction calculator for a specific time and mph for an example... Let's also note, you're going to penalize guys with good air quality and tell them they have to correct to a slower pass?
I didn't see anything about penalizing people for a negative DA, just corrected people above a set DA.
For example, people with a 4000ft DA get .1 tenth
6000 DA get .2 tenths and so on. Just throwing out examples.
I didn't see your correction example, was that from the NHRA correction?
I'll tell you now I've seen local cars run at sea level and pick up 5+ mph.
860whp/677wtq
2.7 V6 Ecoboost
 Old 01-26-2016, 10:42 AM   #48
I'll be stuck in the same class as Bryce and Shawn though. So I'll be the under dog. But it's all good.
dont you weigh like 200 lbs less than bryce?
LumberJack (01-26-2016), SofaKingAwesome (01-26-2016), WetzMS3 (01-26-2016), xfeejayx (01-26-2016)
 Old 01-26-2016, 10:43 AM   #49
LumberJack's Avatar
Groans: 57
Exactly my point... The correction factor is huge from sea level 0 DA to where you're at, hence why the correction was damn near 6mph and .5 ET...
The correction was from an online ET correction website where you can use DA and what not to adjust your times if you were curious about different DA and how it effects your current slip.
 Old 01-26-2016, 11:09 AM   #50
Justin@Freektune's Avatar
Posts: 954   (View Stats)
I wouldn't go that far.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Easter Bunny (01-26-2016), LumberJack (01-26-2016)
 Old 01-26-2016, 11:16 AM   #51
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
You guys need to hire jockeys to drive for you.
@phate; would be a perfect fit.
InkedInspector (01-26-2016), MD1032 (01-29-2016), Micha (04-21-2016)
 Old 01-26-2016, 11:25 AM   #52
Police
InkedInspector's Avatar
Groans: 312
Evan just came up with the best idea ever. Professional drag race jockey. Justin and Bryce can sit in the stands sipping Mint Juleps in suits while their wives or concubines wear goofy hats and bet on the cars.
The Following 6 Users Say Thank You to InkedInspector For This Useful Post:
Easter Bunny (01-26-2016), LumberJack (01-26-2016), Mauro_Penguin (01-26-2016), MD1032 (01-29-2016), Micha (04-21-2016), SofaKingAwesome (01-26-2016)
 Old 01-26-2016, 12:07 PM   #53
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
An example of what my corrected ET and MPH would be given my time/day/track using drag times app.
Seems like it would be the easiest to do.
Edit: Top end only to give us fwd guys a break is lame. If we can't drive, we can't drive.
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
The Following User Says Thank You to udntknw For This Useful Post:
 Old 01-26-2016, 12:15 PM   #54
PapaSmurf's Avatar
That seems pretty believable.
I input my last run from september of 2013 along with using the weather data from the same day and this is what my 11.7 run corrected to. This was when I was on my 35r.
860whp/677wtq
2.7 V6 Ecoboost
Easter Bunny (01-26-2016), udntknw (01-26-2016)
 Old 01-27-2016, 10:26 AM   #55
@Realgib3;, is there any restriction on type of fuel used at Buschur? I looked in the rules and did not see any mention of it. We should clarify that one way or another. Given the gains @LumberJack; recently saw switching to ignite 114, I could see others wanting to make changes if allowed.
I also think that there should be a deadline for these rules to be sorted out and official. Ideally, rules will be set and posted with enough time before the beginning of the competition to allow people time to make hardware changes and tune prior to the beginning of the event.
One last thought. If MSF is committed and really wants to make this a legit competition and an annual thing, I think that the goal for next year should be to host an actual event like Buschur somewhere close to centrally located. I understand that it's already to late to plan something like that for this season, however if planning started for next year soon, there is no reason we couldn't all gather for a weekend in 2017. That would eliminate all of the correction factor arguments, make keeping people honest easier, allow for grudge races, and just be a damn good time. It would take a lot of time and effort to organize, but I see it as the best and perhaps only way to have a legit competition like this.
The Following 6 Users Say Thank You to WetzMS3 For This Useful Post:
Easter Bunny (01-27-2016), Justin@Freektune (01-27-2016), LumberJack (01-27-2016), Mazdazilla6 (01-30-2016), Nliiitend1 (01-27-2016), Realgib3 (01-27-2016)
 Old 01-27-2016, 11:57 AM   #56
LumberJack's Avatar
Groans: 57
Ignite 114 requires a very large fuel system for those thinking about switching over to it. Pump e85 which in my area tested regularly between 85-90% ethanol content was only using about 40-45% of my PI fueling system ( ID 2000's with a 55psi base pressure ) and 90% IDC on the DI side.
Ignite 114 at the same boost and timing levels on the same fuel system brought my PI usage up over 80% so it nearly doubled the amount of injector it was using on the PI side of things, just food for thought when anyone thinks about switching fuels. The Specific Gravity of this fuel is .798
The Following 4 Users Say Thank You to LumberJack For This Useful Post:
Easter Bunny (01-27-2016), Justin@Freektune (01-27-2016), PapaSmurf (01-27-2016), WetzMS3 (01-27-2016)
 Old 01-27-2016, 12:02 PM   #57
Thanks for the info, sir. I actually assumed that it'd have that effect on IDC's without looking it up, but even more so. Knowing those numbers, it may actually be an option for me to consider.
 Old 01-27-2016, 01:34 PM   #58
Realgib3's Avatar
There's no fuel restriction at all, though most either run E98 or Methanol, pump E85 in some of the lower classes. I wouldn't think we should put any restriction on it for this event either.
As for your second point... you read my mind and that's exactly where I was going with the Buschur stuff. It's a really amazing event and I would love for us to eventually be able to make this an actual event like that in the future. I think this is a good start though.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
LumberJack (01-27-2016), WetzMS3 (01-27-2016)
 Old 01-27-2016, 02:13 PM   #59
If we have a stock tune stock turbo class I am in.
 Old 01-27-2016, 02:22 PM   #60
LumberJack's Avatar
Groans: 57
Biggest thing to keep in mind is not if you're injectors are big enough, but if you have enough pump to keep up with those pressures. ID 2000's can be ran up to 130psi with linear flow patterns so I'm not quite pushing mine too hard yet on that aspect. I'd have to say based on the chart ID publishes my 2000s are flowing between 3000-3300cc/min when they will flow up to a max of about 3800ish.
I have a GIGANTIC inline fuel pump which helps a lot
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
PapaSmurf (01-28-2016), Realgib3 (01-27-2016), WetzMS3 (01-27-2016)
 Old 01-27-2016, 03:04 PM   #61
connor_cwp's Avatar
Posts: 119   (View Stats)
connor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond repute
I've never even been to a drag strip and my car is slow but fuck it, why not?
Sent from my SM-N920V using Tapatalk
2009 CWP MS3 Sport
DM EGR Delete, TMM, and PMM. JBR RMM, BSD, Oil Baffle, Shift Weight. HTP 3.5" intake, Under Route IC Piping. Treadstone TR8. AEM gauges. CPE Gauge Pod. Progress RSB. Evo X Enkei. 245 Pilot Super Sport. Rally Armor Mudflaps. Custom test pipe, catback, and MAC EBCS in 3 port.
connor_cwp is offline   Reply With Quote
 Old 01-29-2016, 09:27 AM   #62
Maybe the 5 or 6 of us interested should just meet up at some point this summer?
Seems dead again.
Justin@Freektune (01-29-2016), LumberJack (02-01-2016), Micha (04-21-2016), MS3Shadow (01-29-2016), Nliiitend1 (01-29-2016)
 Old 01-29-2016, 09:28 AM   #63
PapaSmurf's Avatar
Seems dead again.
just like the forum.
Realgib3 likes this.
860whp/677wtq
2.7 V6 Ecoboost
The Following 4 Users Say Thank You to PapaSmurf For This Useful Post:
Micha (04-21-2016), MS3Shadow (01-29-2016), Nliiitend1 (01-29-2016), WetzMS3 (01-29-2016)
 Old 01-30-2016, 02:19 PM   #64
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
I'm in......
xfeejayx and Justin@Freektune like this.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
Justin@Freektune (01-30-2016)
 Old 01-30-2016, 05:09 PM   #65
I'm still not sold on elevation correction for the simple fact of fueling and headroom and a million other factors. But looking forward to the final details and will likely be in regardless. Cause I'll wax dem asses. You too Shawn. Lol
WetzMS3 likes this.
PTE 6062
633HP/523TQ
LumberJack (02-01-2016), mazdafreak (01-31-2016), WetzMS3 (01-31-2016)
 Old 01-31-2016, 09:42 AM   #66
mazdafreak's Avatar
Groans: 124
Not sure if I should groan you or not..........
udntknw and Justin@Freektune like this.
713whp/569wtq!
The Following 3 Users Say Thank You to mazdafreak For This Useful Post:
Justin@Freektune (02-01-2016), LumberJack (02-01-2016), udntknw (01-31-2016)
 Old 02-01-2016, 11:16 AM   #67
Ok, ive read through all of the posts.. So, i agree, it needs to be simpler. We have plenty of time to make these rules before we get started. So lets CHOOSE 3 classes that work. I don't want to create a pissing contest or people being butthurt because of things being unfair. Its bad enough some will get a later start simply because snow hasn't melted or what not.
We could base them off max horsepower or, based off turbo size. Which route do you want to go? I can add an all out STOCK TURBO class to the mix.
 Old 02-01-2016, 11:21 AM   #68
The classing that @Realgib3; laid out similar to Buschur seems to be simple and accepted by those interested so far.
-STOCK TURBO-(ST)
-No Lexan.
-No Lexan.
-QUICK STREET- (QS)
-No Lexan.
The Following 8 Users Say Thank You to WetzMS3 For This Useful Post:
Justin@Freektune (02-01-2016), LumberJack (02-01-2016), Mazdazilla6 (02-01-2016), Micha (02-05-2016), MS3Shadow (02-01-2016), Nliiitend1 (02-02-2016), Realgib3 (02-01-2016), xfeejayx (02-01-2016)
 Old 02-04-2016, 01:12 PM   #69
Easter Bunny (02-04-2016), Micha (02-05-2016), monkey.bones.007 (02-06-2016), MS3Shadow (02-05-2016), Nliiitend1 (02-04-2016), Realgib3 (02-05-2016)
 Old 02-05-2016, 08:20 PM   #70
Micha's Avatar
Posts: 3,436   (View Stats)
I am in for slowest Speed 6. LOL.
WetzMS3 likes this.
WetzMS3 (02-05-2016)
 Old 02-05-2016, 11:22 PM   #71
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
This thing you call racing.
It isn't.
But you had me there for a while.
Mauro_Penguin likes this.
The Following 8 Users Say Thank You to Tomas For This Useful Post:
aaronc7 (02-06-2016), Easter Bunny (02-06-2016), Justin@Freektune (02-07-2016), Mauro_Penguin (02-06-2016), Micha (02-06-2016), Nliiitend1 (02-10-2016), phate (02-05-2016), WetzMS3 (02-08-2016)
 Old 02-09-2016, 12:36 PM   #72
So.....2017 race season?
Easter Bunny (02-09-2016), Justin@Freektune (02-11-2016), Micha (04-21-2016)
 Old 02-09-2016, 01:19 PM   #73
mazdafreak's Avatar
Groans: 124
Im just here to fuck bitches and get money
Justin@Freektune likes this.
713whp/569wtq!
The Following 5 Users Say Thank You to mazdafreak For This Useful Post:
Easter Bunny (02-09-2016), Justin@Freektune (02-11-2016), LumberJack (02-23-2016), PapaSmurf (02-09-2016), WetzMS3 (02-10-2016)
 Old 02-18-2016, 11:19 AM   #74
MSF drag competition or woman president first?
Nliiitend1 likes this.
Easter Bunny (02-23-2016), Justin@Freektune (02-23-2016), Nliiitend1 (02-19-2016)
 Old 02-23-2016, 06:38 PM   #75
WetzMS3 likes this.
Justin@Freektune (02-23-2016), WetzMS3 (02-23-2016)
 Old 02-23-2016, 06:41 PM   #76
Bryce is gonna be low 10's before track even opens up here haha
(must turn him down when he's not looking)
LumberJack and WetzMS3 like this.
PTE 6062
633HP/523TQ
Easter Bunny (02-24-2016), LumberJack (02-23-2016), WetzMS3 (02-23-2016)
 Old 02-23-2016, 06:53 PM   #77
LumberJack's Avatar
Groans: 57
Woah, woah, woah... What kinda friendship is this?! I think I specifically remember you saying "The tuner makes his friends faster"
 Old 02-23-2016, 07:01 PM   #78
sent from my Nexus 6P
ms6mil and Justin@Freektune like this.
The Following 3 Users Say Thank You to MS3Shadow For This Useful Post:
Easter Bunny (02-24-2016), Justin@Freektune (02-23-2016), ms6mil (02-23-2016)
 Old 02-23-2016, 08:21 PM   #79
#inb4rulesaresetrightafterbrycebreaksrecord
 Old 02-23-2016, 08:35 PM   #80
LumberJack's Avatar
Groans: 57
And that's supposed to mean what lol?
I fully intend to break the record regardless sooner rather than later as that's always been my goal.
Very odd breakdown droflow Mazdaspeed3/6 General Discussion 12 09-18-2014 07:45 PM
Breakdown of MS3 Koni Yellow zenit MazdaSpeed 3/6 - Suspension & Brakes 0 09-14-2014 10:35 AM
Breakdown of MS3 front strut zenit MazdaSpeed 3/6 - Suspension & Brakes 17 08-03-2013 11:42 AM
Page generated in 0.62830 seconds with 36 queries
