| Hot Deals Section Share your hot deals from around the web here!! |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
(Thread Starter) | Not Ranked : 0 score 12,000 lb GVW Rhino Ramps for $31. I have these and they are badass and huge. RhinoRamps (up to 12,000lb GVW) - Slickdeals.net
![]() Join Date: Jan 2013 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score Can you drive up these without scraping the front?
__________________ 2011 Mazdaspeed3 non-tech package Drivetrain CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune Chassis JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace Rice LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers |
![]() Join Date: Aug 2013 Location: Santa Fe, New Mexico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 274
| Not Ranked : 0 score I have those! I use them all of the time for oil change. Pretty beefed up and I had no problem. But it'll scrape if you're lowered but it all depends on the angle of the driveway or roads you're using it on TAPPPPPin
__________________ 2008.5 Mazdaspeed3 GT MODS: ETS TMIC - Forge BPV - JBR Tru 3in Intake - JBR Boost/Bypass Hoses - Koni Yellows - Corksport CBE/Corksport Racepipe - Front Corksport FSB (Thanks Previous Owner) - JBR RSB - JBR STS/Heavy Weight Knob - Corksport Aluminum Skid Plate - JBR 88a RMM - Corksport LED Light Kit - Goodridge Braided SS Brake Lines - COBB AP - Corksport HPFP Running on Freektune OTS+ Map Possibly the first deaf MS3 owner here? hmmm... ![]() |
| Not Ranked : 0 score I have a set of ramps (not these) but can't use them since they hit the front bumper before the wheels hit the ramp. On stock suspension too! Sounds like I'm headed to get some replacement ramps. Sent from my SM-G900V using Tapatalk
| I have the same problem. i just put some 2x4 in front and I was able to get onto the ramps just fine. sent from my Nexus 6P
| Not Ranked : 0 score I did the 2x4 thing for a while but stopped when it was wet and the 2x4 slipped out. Currently I'm using a pair of 2x6 boards glued and screwed together and chamfered to make a multi-stage ramp. So far so good on these but it would be nice to have something a bit higher so I don't have to bust out the jack stands for oil changes. Sent from my SM-G900V using Tapatalk
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score 2x4s in front of ramp is all I need, not on the ramp where they will slip off. I have no problem doing oil changes under these...only reason I bought them really was to do oil changes.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
(Thread Starter) | Not Ranked : 0 score Nearly the same deal currently available at Advance Auto Parts: RhinoGear RhinoRamps Vehicle Ramps (12,000-lb capacity) - Slickdeals.net
| Ball Regular-Mouth Quart Mason Jars w/ Lids and Bands (Set of 12) $8 + Free Store Pickup | aviator79 | Hot Deals Section | 3 | 03-30-2014 03:09 PM |
| Rhino lined roof ms3 | I Love Brownies | Appearance - SILVER | 123 | 03-05-2014 04:20 PM |
| 10-piece Craftsman Evolv Deep Impact Socket Set (Standard or Metric) $15 + Free Store Pickup | aviator79 | Hot Deals Section | 4 | 01-12-2014 07:04 PM |
| $5 Off $20 In-Store Coupon Walgreens at Online Store | Haltech | Hot Deals Section | 0 | 04-11-2008 07:11 AM |
