| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Jun 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hi! I have a 3" catless exhaust, hpfp internals, fmic. I installed the ots tune from Versatune for 98 octane high load high flow downpipe. Unfortunately my WGDC quickly goes up, while my boost pressure drops with load as well. No knock is detected. Do I have a boost leak? Whcih components do I have to check, like bpv and wastegate? Thanks for the help! |
| The Following User Says Thank You to deakgegi For This Useful Post: | zaclaw (02-11-2020) |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 549
Groans: 105
| Not Ranked : 0 score LOL
__________________ Stockish |
| The Following User Says NO Thank You to Db09ms3 For This Un-useful Post: | MSMS3 (09-18-2019) |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Did you even look at his f’kin log, or do you know what to look for?
(Thread Starter) | Not Ranked : 0 score Could you help please? |
Groans: 105
| Not Ranked : 0 score No
(Thread Starter) | Not Ranked : 0 score Or atleast guide me to the right direction.. |
Groans: 105
| Not Ranked : 0 score Any CEL's? Any changes in driveability?
(Thread Starter) | Not Ranked : 0 score No CEL's, pretty same driving experience. |
Groans: 105
| Not Ranked : 0 score Time for a protune
(Thread Starter) | Not Ranked : 0 score Anything I should consider changing in the tune to get the expected load results and lower wgdc? |
The K04 cannot sustain 17 psi at high rpm on pump gas. It turns into a flamethrower and just superheats the air. Boost has to taper to 15 psi approaching redline to save itself, and that is what it is properly doing. You may get more power by reducing boost up high, increasing timing and keeping AFR rich. What fuel? Run the best 93 octane or add a couple gallons of E85 per tank of gas.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 09-18-2019 at 10:43 PM. | |
(Thread Starter) | Not Ranked : 0 score Thanks for the helpful review, I appreciate it! I'm running on OMW MaxxMotion 100 in Europe. I've seen others here running even 20 psi, and holding 18 psi under high rpm with the ko4 I'm only flowing around 220 g/s, isn't that too low? Please tell more that can help me understand the situation. Even the OTS map targets a higher boost and much lower WGDC, that's why I think I might have mechanical problem. I'm really happy to learn if my situation is normal, but I want to know the reasons. |
| Not Ranked : 0 score for sure, a tune won't help to make more boost when the wastegate duty is already maxed out on the turbo....(A proper tune have other benefits but not thoses) But keep in mind the boost level isn't that revelant, it tell more about the restriction of your engine. One could be making twice your power with the exact same boost level with huge turbo and engine works.... What is strange is flow level, you actually have a less restrictive exaust that should allow for more flow at this wastegate duty level. I would be expecting 260-280g/s... If you would have a leak after the turbo, that reading would just increase... You could have a bad maf scaling into the tune against your intake size....this would be confirmed by the maf cal. process.... If you aren't very higher than sea level and all the above is ok, you may have something restrictive in the intake or exhaust path.... You may also have something wrong with your ebcs....you may try to disconnect it(electric) and see if it reduce your power a lot like it should happen. If not you may check if the bypass air path is ok and if the solenoid operate well. You can also check if the wastegate rod is holding tight the flapper inside the turbo. there is a lot more things that could make this....a damaged turbo wheel, leaking wastegate flapper, a bad filter etc...........
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 09-19-2019 at 07:49 AM. |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (09-19-2019) |
(Thread Starter) | Not Ranked : 0 score I currently have stock intake, so I'm using the ots calibration. The tubing after the turbo has no leaks, holds 2 bar steady no problem. My next tought is to check the wastegate and the ebcs as well. If I disconnect the ebcs connector, I will be running on spring pressure, so I will lose some boost, right? If I make the same figures, it means something is wrong with the ebcs. I have an open 3" exhaust with no cats, the car was serviced lately, so it should have nothing inside. Also sounds great, can't really hear anything special. I will get some more logs today and post them here, thanks for the help! |
| Not Ranked : 0 score stock intake ? you mean the oem restrictive plastic box with a square paper filter ? or oem size maf hosing ? i never tested a k04 on spring pressure with your conditions to validate but it would be like 0%wg duty....but restrictions in the vaccuum line returning to the turbo inlet hose would decrease the effect of the wastegate duty as well
| Not Ranked : 0 score I went back and looked at some of my old logs. At 220 g/s mass air flow, the wastegate was more at 55-60% duty cycle under load. Know this, though: g/s alone is not the story. If the fuel is rich and timing is advanced, you can make a lot more power on the K04 than people realize based on air mass flow alone. I don't think my tune ever allowed more than 240-250 g/s with a good aftermarket high flow AEM/Mazdaspeed CAI and catless 3" dp/rp,. But, with very aggressive timing advance of 17-18 degrees at high rpm and rich AFR for cylinder cooling to permit that much timing without knock, it was making 300-310 whp on 93 pump gas on the little K04. I think there must be a combination of low flow on the intake side and something going on regarding the operation of the wastegate (EBCS, wastegate actuator, wastegate flap or such). Just a suspicion. It's probably hitting target boost for the tune, but working way too hard to get there.)
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 09-19-2019 at 03:55 PM. |
| Not Ranked : 0 score with full bolt on for my 6 and a 2.5'' exaust i was seeing above 260gs without going that high in wg duty for sure but i don't have much logs or the k04 to test again....
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (09-21-2019) |
| Overshooting load targets, low wgdc - what's wrong? | mituc | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 03-14-2016 08:05 AM |
| WGDC being pulled despite being well below boost/load targets | MD1032 | 2010 MS3 - ECU Computer Tuning | 5 | 12-04-2015 04:46 PM |
| WGDC Inconsistencies with Boost Tuning - Random flatline and no wgdc compensation | phate | 2010 MS3 - ECU Computer Tuning | 38 | 02-10-2013 01:49 PM |
| No change in boost from 0% WGDC to 100% WGDC | phate | MazdaSpeed 3 - Engine, Transmission & Driveline | 30 | 12-12-2011 03:27 AM |
| 0 WGDC, High Load, Low Boost | RJTSi | Cobb ATR Support | 6 | 01-19-2010 10:04 AM |
