| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
(Thread Starter) | Not Ranked : 0 score Getting a lot more random knock while cruising and partial throttle situations. Getting high partial throttle/WOT cut outs which from my untrained eye look like possible boost cuts at WOT. It is quite cold outside ~32F so these maps may be struggling. If the tuning gods could take a look and chime in with some suggestions I would greatly appreciate that. 2 4th gear WOT runs tonight with ambient temps around 32F:
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 364 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 480
| Not Ranked : 0 score Without looking at your logs I would say this is the same thing I had. I had to reduce my wgdc table. Someone who diagnosed my problem should be able to help you. Sent from my HTC Droid Incredible using Tapatalk
__________________ CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers! |
(Thread Starter) | Not Ranked : 0 score That's what I figured. How much do I need to reduce WGDC by? When it's cold I assume I have to have higher values but the temps around here vary from 60 during the day to low 30s at night. I assume its possible to find some sort of balance in this cold weather. Also can someone chime in on the knock which is a lot more prevalent in the 2nd log. Got as much as 3 degrees on the second run. Will getting the boost closer to target levels help eliminate all this knock that i get?
| Not Ranked : 0 score You need an adjustment to both timing and a little trim with boost but that's not too bad.
| Not Ranked : 0 score Karmat, You are getting large amounts of wgdc hacked from your table by the wgdc load error comp table. You can either raise your trl - x gear tables to about .1 above logged calculated load per rpm, or decrease the authority of the wgdc load error comp table. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Karmat (12-05-2011) |
![]() Join Date: Jan 2011 Location: Scranton, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,797
Groans: 62
| Not Ranked : 0 score I had the same issues with those maps, decided to just tweak a v107 map. I'm also a dumbass at tuning.
__________________ Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL |
| Not Ranked : 0 score I would take Lex's suggestions, given you do have some pretty substantial knock in the second log. Before tuning boost any further, it would definitely be a good idea to back out some timing. Last edited by rfinkle2; 12-05-2011 at 01:39 PM. |
(Thread Starter) | Not Ranked : 0 score I'm going to flash back the v107 map for now while I finish up the semester and finals. I will have some time during winter break to play around with the v200 maps. v107 didn't give me any problems although the car feels to pull a lot harder with the v200. Thanks for the input guys.
| The Following 2 Users Say Thank You to Karmat For This Useful Post: | Don06speed6 (12-05-2011), rfinkle2 (12-05-2011) |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,528
| Not Ranked : 0 score ^^ same boat here. I have a v108 map that ive been running for over a year. Recently got my firmware updated, loaded the v200 map. butt dyno recorded a substantial improvement, but got some random knock i couldnt replicate the knock on either load or RPM ranges, so im thinking its just shitty seals or something, but it was there a lot so, I went back to 1.08 maps since I had some track events coming up.... but im currently spending some time on the v200 maps, and im excited to figure the knock out of it. |
| The Following User Says Thank You to super_pablo_ For This Useful Post: | rfinkle2 (12-15-2011) |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score IMO the OTS V2xx maps still need a lot of tweaking to get right. In my own experience, they seem to be somewhat unpredictable. Part of the problem I've seen with those maps is the huge ramp on the overboost side of the BEC table.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
| The Following 2 Users Say Thank You to SRTie4k For This Useful Post: | Boost_creep (12-15-2011), rfinkle2 (12-16-2011) |
| Not Ranked : 0 score ^^ what do u mean? My BEC tables had higher correction values on previous maps... maybe i tweeked em? i dont fucking remember lol... last map i revised was over a year ago (other than the one im currently working on) |
| Problem. Without meth tune is great. On Meth tune shits the bed. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 16 | 09-06-2011 06:58 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
| is it possible to tune over 22psi of boost with | johnac08 | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 09-11-2009 01:55 PM |
| ideally whats the best boost targets for custom tune from full boost to redline? | Wenis Prinkle | Cobb ATR Support | 26 | 08-24-2009 06:36 PM |
