| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: May 2009 Location: Kingston MA
Rep Power: 227 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 258
(Thread Starter) | Not Ranked : 0 score Just installed my CorkSport SRI/TIP yesterday and will probably be installing the AccessPORT during the week. Do I need colder plugs with so few mods?
__________________ 2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,186
| Not Ranked : 0 score I have yet to be fully convinced that colder plugs actually do anything. I have yet to get them and don't plan on getting them until I see hard proof that they help. Most install posts I have seen end up having problems rather than benefits. Please, somebody help OP and prove me wrong.
__________________ T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels |
Groans: 239
| Not Ranked : 0 score heat range of plugs does not affect horsepower. colder = less likely detonation/preignition, too cold = misfire, stumbling etc. |
![]() Join Date: Oct 2009 Location: Pasadena, MD
Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score A buddy of mine is running 1 step colder plugs (IVT-22's) with Cobb SRI/TIP and the OTS Stage1+sf w/ an AP. I helped him install them and he has been running great with no problems for around 30-40,000 miles.
__________________ 2013 Mustang GT - California Special |
| The Following User Says Thank You to niterydr For This Useful Post: | wette460 (03-24-2011) |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
| Not Ranked : 0 score Wrong you are my little asian friend. Spark blow out is going to affect power. This becomes an issue once you start throwing more air and fuel at our motors.
__________________ |
| The Following 3 Users Say Thank You to Amazon For This Useful Post: |
![]() Join Date: Mar 2010 Location: Columbus, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score If you start adding boost and improving intake your going to increase heat in the cylinder. Step colder will allow the plug to properly deal with the heat, reducing the chances of plug melting and knock. I've had a TMIC, SRI & CBE and had step colder plugs in since 3K miles and had no issues with running them. That true but as long as you properly gap your plugs you'll be ok.
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,709
| Not Ranked : 0 score I had all sorts of hesitation and cuts as soon as I got an intake, it carried on when I got my HT and only stopped when I fitted itv22's. |
Groans: 239
| Not Ranked : 0 score my venezuelan counterpart, i guess i worded it incorrectly or maybe i am perciving it wrong, blow out/misfire/stumbling etc to me is the engine unable to mechanically deliver the power it needs. if a engine can run at a heat range of 8, running 7 or lower will only decrease the chances of said detonation/pre ignition and of course too low like i stated above misfire etc etc. in no way does spark plugs increase hp is wat i mean or decease horsepower, just allows the engine to perform at peak efficency |
Groans: 214
| Not Ranked : 0 score Properly gapping isn't going to help if your plugs have too hot of a spark for your application. Once again my asian philippino, if your sparks aren't igniting the fuel/air mixture due to blow out, then the engine will suffer power loss, albeit a slight amount. I have some logs of stock plugs vs cooler plugs if ya would like to see the difference plugs can make.
Blowout can seriously seriously hamper the "power" of a car lol. You could actually see the blow out in my logs, with stair stepper rpm curve lol. It was some funny shit.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() Join Date: Dec 2010 Location: Dayton, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,193
| Not Ranked : 0 score So what plugs are you guys running? The Denso or a colder NGK? |
Groans: 214
| Not Ranked : 0 score One of the guys had issues trying to get the NGK's to gap since they come pre gapped too wide. Most of us tend to go with Denso.
| The Following User Says Thank You to Amazon For This Useful Post: | ak_spray (03-10-2011) |
Groans: 239
| Not Ranked : 0 score well my muchacho the efficeny of the engine affects how it performs and how much power it can put to the ground, im not arguing with you there, and yes obv if your spark is blowing out then ignition isnt happening meaning no power agreed, the point i was trying to make is that, if an engine is operating at peak efficeny, switching heat ranges on a plug aslong as there is no misfire/detonation etc etc, horsepower will not change. the point of proper heat ranged plugs is to have the "correct" temp for ignition without misfire/detonation etc. make sense or am i speaking gook again? |
(Thread Starter) | Not Ranked : 0 score Car had been running awesome with just the intake for 250 plus miles, so I installed the AP on Tuesday. Started out running Stage1 + SF 91 Octane 1.08 map and noticed I got a lot of partial throttle surging, along with a very digital (on/off) throttle pedal. Switched to the Stage1 91 Octane map and it was worse at first, but after 50 or so miles the problem has become much less prevalent, but it still seems to be there. Logged a 4th gear pull which seems pretty good albeit maybe a little lean (see attached). Guessing that some of my problems are the uncalibrated MAF, but have also heard people with similar issues on the stock plugs. Seems that as soon as they jump over to the ITV22s, their surging and touchy throttle problems go away.
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) | |
| The Following User Says Thank You to MattJackson86 For This Useful Post: | djuosnteisn (03-10-2011) |
![]() Join Date: May 2010 Location: Burlington, VT
Rep Power: 186 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 202
Groans: 50
| Not Ranked : 0 score When do you think it makes sense to go a step colder? I will be installing my TIG and and test pipe soon. Do you think it makes sense with my setup?
__________________ 08.5 CWP MS3 GT Cobb SRI & TIP | Jbarone SSP & Bushings | SURE RMM | CS Racepipe | ASA AR1 w/ Conti DW 235/40/R18 |
I dunno if heat range has an influence on spark. I want to say it shouldn't but who knows. I say run the warmest plug you can as long as your not having detonation issues. I plan on running 1 step colder plugs, and gapped tighter if necessary. AFRs play a huge role as well. As does nozzle size if you spray water / meth injection. Everything seems to contribute. I would say after a couple bolt ons, and a tune, it's smart to go 1 step. But i wouldn't go any colder unless you have to.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | MattJackson86 (03-10-2011), wette460 (03-24-2011) |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
| Not Ranked : 0 score I've always wanted to ask if ambient temps affect what range plugs to run. I have mods in sig and am just starting to get into ATR to turn up the boost a little bit. But I live where in the winter my car will sometimes have to sit outside for 9 hours at -10F while I am at work. Then I need it to be able to start and run till it warms up which takes quite a while at those temps. Will the colder plugs not run as well in the cold weather?
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
| Not Ranked : 0 score I have no clue lol. I haven't played with different heat ranges that much. But at one heat range colder, i don't think you'd see any appreciable difference from stock.
From Denso IR Power FAQ Site
__________________ | ||
| The Following 4 Users Say Thank You to RacerX78 For This Useful Post: |
![]() Join Date: Jan 2011 Location: Irvine, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score Very helpful info, thanks |
Groans: 50
| Not Ranked : 0 score Agreed but I still have no clue what I'm going to do. I figure new stocks are better than mine with 30k on them.
![]() Ill try tightening the plugs. I am running 2 step colder now gapped at .027 and was going to stick with the same, not sure if I should only go 1 step colder though. I have had no issues with 2 step overall though.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | djuosnteisn (03-11-2011) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Something basic rule with plugs are go one step colder for every 75-100Hp you add over stock power. If your doing just a TIG with your SRI and TP you'll be fine with new stock heat range plugs.
![]() | | #25 | ![]() |
Groans: 60
I'm running two steps colder with my gt35 but I run at least 21psi daily, and do not have meth injection. If I hadn't spent $27 each on these HKS plugs I'd probably have switched back to one step colder plugs, because I don't think two steps is even necessary where I'm at currently...and they run like shit until the car is completely warmed up.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
| The Following 3 Users Say Thank You to SSinstaller For This Useful Post: |
![]() | | #26 | ![]() |
![]() Join Date: Feb 2010 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 606
| Not Ranked : 0 score Can step colder plugs with just a SRI, TIP, TMIC, and RP cause any backfiring/afterfiring between a 2-3 shift? I just switched mine to step colder Denso's in anticipation for my AP install (I haven't installed the AP yet) and I seem to be getting a little backfire in-between my 2-3 shift... (I also did some work with my BPV, I installed a spring rated for 20-25psi instead of the 10-20psi spring that was initially in it...)
__________________ Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC |
![]() | | #27 | ![]() |
Groans: 60
BPV possibly It's always a good idea to change one part at a time, it makes trouble shooting the issues much easier.
| The Following User Says Thank You to SSinstaller For This Useful Post: | myt_tuf1 (03-10-2011) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score I've got a SRI, TMIC and CBE and i get backfire when i shift at WOT every now and then. I don't get it during my DD.
![]() | | #29 | ![]() |
Groans: 239
| Not Ranked : 0 score um, when you detonate after having the improper heat range, youll be convinced. but i doubt you will be pushing your car to that limit anyway. wtf is that runescape link? |
![]() | | #30 | ![]() |
Groans: 214
| Not Ranked : 0 score He's basically soliciting. Cut that shit out. And Runescape is gay.
![]() | | #31 | ![]() |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | bcmountainspeed (03-12-2011) |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just installed the plugs right from the box. They come pre gapped, so I didn't mess with them.
![]() | | #34 | ![]() |
| Not Ranked : 0 score See that has caused issues for me (and others) in the past. I know our suggested gap is between .024-.032. I have found I have to run a closed gap or I have issues and out of the box they are not pre-gapped correctly.
![]() | | #35 | ![]() |
The recommened gap for itv22's is .024-.027 if you are running a COBB AP. I know you were questioning exactly what gap to run, and I haven't heard anyone from the low (.024) to high range (.027) say they had an issue. FWIW, Denso suggests that iridium plugs are much less sensitive to gapping issues due to their efficiency. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | Chriscote (01-30-2012) |
![]() | | #36 | ![]() |
Groans: 214
| Not Ranked : 0 score I sense faggotry in this thread
![]() | | #37 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Heat range and blowout have nothing to do with one another. Blowout is caused by high cylinder pressure and weak spark induced by that, or too large gap settings. The heat range is merely the survival range of the plug in a situation of INCREASED CYLINDER PRESSURE (read: EXTRA HEAT) and, a measure of the plugs ability to clean itself off of unburned HCs at startup and cooler weather. A colder plug will more effectively transfer that extra heat to the cylinder head and thus the cooling system, rather than retaining it in the plug body, widening gaps, distorting tips, causing pre-ignition or worst case, melting altogether. A too-cold plug WILL decrease power SLIGHTLY over a proper range for the conditions it's in. It's safer to err on the side of caution but, you really have to READ the plug that's in the motor to determine if going colder is necessary. I went over the line at near full bolt and only barely so, I think you're safe, unless you're booting around in Venus-level ambient temps. I do get some fouling issues at startup in freezing temps. |
![]() | | #38 | ![]() |
Cold starting wasn't a problem in these few cases, but very well may be a problem if your current setup is not exhibiting any problems now. I guess the moral of the story may be... if it ain't broke... | |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score Faggotry asside, what are you using to gap your plugs? I'm coming from naturally aspirated V8's with carburetors where the plugs were not made with precious metal. All I have is a set of feeler gauges, and from what I know about gapping precious metal plugs, contacting the electrode is a no no. I guess I could have brought the plugs into work and used the vision system to measure them, but that seems a little excessive. Right from the Denso website: Q. Do I need to set the gap? A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip. Q. How do I gap Iridium plugs A. Before attempting to gap any DENSO Iridium Power spark plug, please review the specification chart to see the factory-preset gap. In most cases your Iridium Power plugs do not need to be gapped. Even with small variations in the factory set gap the ultra-efficient firing power design will compensate for those small variations. Should you decide to re-gap your Iridium Power plug, use extreme caution as improper gapping may damage or destroy the Iridium center electrode or porcelain center. To increase the gap size: Step 1 Use needle nose pliers or spark plug gapping tool to bend the ground strap up to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN. Step 2 Re-check the gap with a calibrated gapping tool. To decrease the gap size: Step 1 Use the same method as above, however bend the ground strap down to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN. Step 2 Re-check the gap with a calibrated gapping tool. WARNING: Failure to follow these directions may permanently damage the spark plug. Note: Never use a round gapping tool to check the gap or to increase or decrease the gap setting. http://www.globaldenso.com/en/produc...ium/qa_22.html
![]() | | #40 | ![]() |
| Not Ranked : 0 score SpeedRac3R... You'll need a "feeler" gauge available @ any local auto parts store. When you get it, keep in mind that you may have to use 2 "feelers" @ once to equal the gap u want. eg... although may not be the actual feeler numbers .025+.002=.027 Just be weary of touching the actual irridium, and use a good pair of needle nose pliers to open the gap, and tap the plug on top to close it. There are a few vidoes... on sites other than denso. Try ngk's site.... |
| Do I need step colder plugs? | drenkel | 2010 MS3 - Engine, Transmission & Driveline | 1 | 07-13-2010 01:43 PM |
| Should I go with colder plugs | AllLostThings | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 05-28-2010 11:16 AM |
| colder plugs? | triple_threat | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 12-19-2009 11:07 AM |
| KR and Colder Plugs | Qluber | MazdaSpeed 3 - Engine, Transmission & Driveline | 21 | 03-20-2009 08:26 AM |
| 1step colder or 2 step colder plugs, need to decide which plugs before tune day(by CHURCH) | johnac08 | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 12-13-2008 04:17 PM |
