| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Mar 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Neutral : +1 score So I got my AP today, and to celebrate I coded a CSV web based grapher for my data logs. CSV Grapher v0.1a It isn't up to par with what you DH folks have, but it works for me ![]() UPDATE: Got on it after 50 miles. Pulls like crazy 1st-3rd gear, but 4th+ feels tame, albeit stronger than stock. Stage 1+ v1.03 WOT logs look clean to me, however, the second log is from a non-launch start from 1st gear. The fuel pressure sensor PSI drops below 1400, which is a bit unnerving IMO. But then again, my wheels are spinning at that point so I modulated the throttle (boost drops), so I guess its expected? It's about 60 degrees, sea level, CA 91.Log 1:- 3rd gear pull Log 2: w/wheels slipping Regarding the CSVG, Let me know if anything is unclear, have any suggestions, or if you find any bugs D: Also, if you put in ridiculously large log files, you'll have to wait a few seconds for everything to render. HAVE FUN - DON'T BREAK IT ![]() Thanks to xandrake for posting his CSV file and Haltech for letting me use his MS3 image without permission ![]() TODO (3/31/09): * More Color Choices * Thicker Font * Input new data without refreshing the page * Tool to help trim logs Last edited by Y o o z; 04-01-2009 at 05:10 PM. |
| The Following 23 Users Say Thank You to Y o o z For This Useful Post: | 94jedi (04-14-2009), Arrowpoint (04-14-2009), Caldazar (06-13-2010), dallasms3gt (04-03-2009), danesti (11-16-2009), djthom (06-12-2009), dread (05-02-2009), Enki (03-21-2011), evidence (04-03-2009), Ferdball (11-02-2009), Fobio (04-01-2009), FreeFlyFreak (04-28-2009), Haltech (04-03-2009), jayspeed3 (07-04-2009), K7addict (12-22-2010), labikesrcool (06-24-2011), LatinKraze (08-23-2011), nuprin503 (02-22-2011), Qtip (03-25-2010), RayRayBauder (08-22-2009), SSLow3 (04-01-2009), Stan-O (04-01-2009), xandrake (04-05-2009) |
![]() Join Date: Jul 2008 Location: DFW
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 11
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score This should be stickied, good work. I'm in the process of building one in VB.NET to use Excell in the background, but we'll see how it goes.....
__________________ Speed-less |
| Not Ranked : 0 score when i click ok it doesent make a graph for me EDIT: nm
![]() Join Date: May 2008 Location: Sayreville, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score Thanks for the Graphing Tool! Def should be stickied.
__________________ All content created by this user is for entertainment purposes only. Mods: Wouldn't you like to know |
| Good work!
![]() Join Date: Sep 2008 Location: Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 276
| Not Ranked : 0 score +1 on the sticky! Thannnnnk you! |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score hmm ya i've having some difficulties with it as well. I paste my .csv data log from wordpad into the text box and hit graph and nothing happens. I've tried 3 different browsers and non work (IE7, Chrome and FireFox). got it working, great tool and thanks!
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package Last edited by Matrix311; 04-14-2009 at 10:33 AM. Reason: got it |
First, You need to watch out for any weird characters in the first cell. such as: Seconds (sec) should actually be Seconds (sec) Also, your data should look like this: Seconds (sec),Accel. Pedal Pos. (%),Knock Retard (°),RPM (RPM),Actual AFR (AFR),Fuel Press. Sens. (PSI),Boost (PSI) 0,16.38,0,2207,14.99,1154.46,-8.56 0.21,16.38,0,2220,14.55,1137.06,-8.7 0.48,16.38,0,2226,14.7,1129.8,-8.7 0.77,16.77,0,2235,13.96,1141.41,-8.7 1.02,16.77,0,2236,14.55,1126.9,-8.7 1.26,16.77,0,2238,14.55,1147.21,-8.7 1.52,16.77,0,2228,14.85,1138.51,-8.7 1.78,24.57,0,2235,14.99,1171.86,-8.56 2.05,53.04,0,2234,14.99,1147.21,-7.83 2.32,99.06,0,2302,14.41,1654.82,0.29 2.57,99.06,0,2415,13.67,1675.13,3.48 2.83,99.06,0,2486,13.38,1609.86,6.53 3.11,99.06,0,2629,12.64,1721.54,13.49 3.4,99.06,0,2844,12.49,1595.36,17.4 3.64,99.06,0,3051,12.35,1641.77,18.42 3.93,99.06,1.05,3213,11.76,1682.38,18.42 4.17,99.06,0.35,3632,12.35,1654.82,17.69 4.45,99.06,0.35,3672,12.35,1675.13,17.26 4.71,99.06,0,3862,12.35,1741.84,16.97 4.99,99.06,0,4100,12.35,1659.17,17.11 5.28,99.06,0,4271,12.35,1714.29,16.68 5.52,99.06,0,4393,12.2,1686.73,16.24 5.81,0,0,4629,29.25,1679.48,15.81 6.01,0,0,4564,29.25,1689.63,-3.19 6.31,0,0,4067,29.25,1728.79,-12.62 6.57,0,0,3761,29.25,1746.19,-12.62 6.84,0,0,3331,29.25,1763.6,-12.62 7.06,0,0,3280,29.25,1781,-12.33 7.27,0,0,3225,29.25,1791.15,-11.89 7.57,0,0,3199,29.25,1798.4,-11.89 7.83,0.39,0,3160,29.25,1811.46,-11.89 8.08,0,0,3146,29.25,1823.06,-11.75 8.3,0,0,3113,29.25,1830.31,-11.75 8.57,0,0,3090,29.25,1836.11,-11.75 8.82,0,0,3051,29.25,1846.27,-11.6 9.05,0,0,3024,29.25,1854.97,-11.75 9.31,0,0,3009,29.25,1857.87,-11.6 9.54,0,0,2984,29.25,1860.77,-11.6 9.78,0,0,2952,29.25,1862.22,-11.6 10.07,0,0,2934,29.25,1862.22,-11.6 10.31,0,0,2894,29.25,1862.22,-11.6 10.58,0,0,2879,29.25,1862.22,-11.75 10.86,0,0,2845,29.25,1862.22,-11.6 11.1,0,0,2810,29.25,1862.22,-11.75 11.33,0,0,2783,29.25,1862.22,-11.75 11.56,0,0,2755,29.25,1860.77,-11.75 11.8,0,0,2730,29.25,1862.22,-11.75 12.09,0,0,2714,29.25,1862.22,-11.75 12.34,0,0,2679,29.25,1862.22,-11.75 12.54,0,0,2645,29.25,1862.22,-11.89 12.8,0,0,2629,29.25,1860.77,-11.75 13.02,0,0,2604,29.25,1860.77,-11.89 13.3,0,0,2574,29.25,1862.22,-11.89 13.58,0,0,2552,29.25,1862.22,-11.89 13.85,0,0,2527,29.25,1860.77,-11.89 14.07,0,0,2493,29.25,1862.22,-11.75 14.32,0,0,2475,29.25,1862.22,-11.89 14.52,0,0,2443,29.25,1862.22,-11.75 14.74,0,0,2423,29.25,1862.22,-11.75 14.94,0,0,2397,29.25,1862.22,-11.75 15.15,0,0,2384,29.25,1862.22,-11.75 hope that helps.
__________________ All content created by this user is for entertainment purposes only. Mods: Wouldn't you like to know | |
![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 631
Groans: 40
| Not Ranked : 0 score how do i copy the image so i can paste it here?? |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
| Not Ranked : 0 score Nice work. But is there any chance that we can save the graph as a jpg or png file? |
(Thread Starter) | Not Ranked : 0 score Its rendered inside of the browser, so not really. What you can do, is press the "Print Screen" button on your keyboard, Paste it into MSPaint (or whatever image editor you use) and crop it to your liking. |
![]() Join Date: Sep 2009 Location: Plymouth, MA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score Seconds (sec),RPM (RPM),Knock Retard (°),Calculated Load (%),Long Term FT (%),Mass Airflow (g/s),Short Term FT (%),Actual AFR (AFR),DI Fuel Press. (PSI),Boost (PSI) 0.00,3265,0.00,203.45,-0.16,154.59,-0.16,12.20,1577.96,18.71 0.11,3312,0.00,198.74,-0.16,162.24,-0.16,12.05,1609.86,18.13 0.23,3366,0.00,200.31,-0.16,168.81,-0.16,11.91,1622.92,18.56 0.35,3406,0.00,204.62,-0.16,175.53,-0.16,11.91,1707.03,18.85 0.47,3440,0.00,204.62,-0.16,172.14,-0.16,11.91,1592.46,18.56 0.57,3490,0.00,200.31,-0.16,172.14,-0.16,11.91,1689.63,18.13 0.67,3539,0.00,195.22,-0.16,170.14,-0.16,12.05,1738.94,17.98 0.77,3588,0.35,193.26,-0.16,176.21,-0.16,12.05,1738.94,18.13 0.87,3616,0.35,194.43,-0.16,178.26,-0.16,11.76,1746.19,18.42 0.97,3683,0.35,195.22,-0.16,179.65,-0.16,11.91,1721.54,17.98 1.07,3737,0.35,192.86,-0.16,178.96,-0.16,11.76,1627.27,18.13 1.17,3768,0.00,192.86,-0.16,185.24,-0.16,11.76,1662.07,17.98 1.27,3822,0.00,191.30,-0.16,183.12,-0.16,12.05,1659.17,17.69 1.37,3894,0.00,190.90,-0.16,189.50,-0.16,12.05,1686.73,17.55 1.47,3916,0.00,190.51,-0.16,186.65,-0.16,12.05,1714.29,17.40 1.57,3966,0.00,187.77,-0.16,191.67,-0.16,12.05,1622.92,17.55 1.67,4010,0.00,188.16,-0.16,195.31,-0.16,12.05,1675.13,17.26 1.77,4045,0.00,188.55,-0.16,196.78,-0.16,11.91,1669.33,17.26 1.87,4100,0.00,188.16,-0.16,196.78,-0.16,11.91,1686.73,17.26 1.97,4139,0.00,187.77,-0.16,199.73,-0.16,12.20,1709.93,16.97 2.07,4176,0.00,186.59,-0.16,201.23,-0.16,12.05,1644.67,16.82 2.17,4242,0.00,185.81,-0.16,199.73,-0.16,12.05,1721.54,16.82 2.27,4268,0.00,185.81,-0.16,202.74,-0.16,11.91,1692.53,16.97 2.37,4305,0.35,186.20,-0.16,205.76,-0.16,11.91,1728.79,17.11 2.47,4363,0.00,185.42,-0.16,208.06,-0.16,11.76,1679.48,17.11 2.57,4391,0.00,185.42,-0.16,206.52,-0.16,11.91,1672.23,16.82 2.67,4451,0.00,185.02,-0.16,215.83,-0.16,11.91,1615.66,16.82 2.77,4496,0.00,185.02,-0.16,214.26,-0.16,12.05,1734.59,16.97 2.89,4520,0.00,183.46,-0.16,214.26,-0.16,11.76,1675.13,16.97 2.99,4581,0.00,184.24,-0.16,218.19,-0.16,11.76,1711.39,16.97 3.09,4615,0.00,183.85,-0.16,218.99,-0.16,11.91,1714.29,17.26 3.19,4673,0.00,183.46,-0.16,219.79,-0.16,11.91,1707.03,17.26 3.29,4714,0.00,183.85,-0.16,225.42,-0.16,11.76,1679.48,17.26 3.39,4723,0.00,184.63,-0.16,226.24,-0.16,11.76,1746.19,17.40 3.49,4789,0.00,183.06,-0.16,223.00,-0.16,11.76,1682.38,17.26 3.59,4841,0.00,180.71,-0.16,227.88,-0.16,11.76,1751.99,17.26 3.69,4876,0.00,180.32,-0.16,228.70,-0.16,11.76,1664.97,17.40 3.81,4905,0.00,180.32,-0.16,232.83,-0.16,11.76,1672.23,17.11 3.91,4960,0.00,180.71,-0.16,233.66,-0.16,11.76,1637.42,17.26 4.01,4996,0.00,179.93,-0.16,234.50,-0.16,11.76,1676.58,17.26 4.11,5030,0.00,180.32,-0.16,237.01,-0.16,11.76,1731.69,17.26 4.21,5081,0.00,179.14,-0.16,236.17,-0.16,11.76,1728.79,17.26 4.31,5112,0.00,178.75,-0.16,236.17,-0.16,11.76,1699.78,17.11 4.41,5112,0.00,178.75,-0.16,236.17,-0.16,11.76,1699.78,17.26 4.51,5165,0.70,176.79,-0.16,237.01,-0.16,11.76,1675.13,17.11 4.61,5201,0.70,175.62,-0.16,241.25,-0.16,11.47,1615.66,17.11 4.71,5241,0.70,175.62,-0.16,240.40,-0.16,11.61,1666.42,17.11 4.81,5289,0.70,174.44,-0.16,241.25,-0.16,11.61,1651.92,16.97 4.91,5323,0.70,173.26,-0.16,241.25,-0.16,11.47,1738.94,16.97 5.01,5357,0.70,172.87,-0.16,245.53,-0.16,11.61,1741.84,16.97 5.11,5357,0.70,172.87,-0.16,245.53,-0.16,11.47,1741.84,16.97 5.21,5403,0.70,172.48,-0.16,246.40,-0.16,11.47,1612.76,16.68 5.31,5458,0.35,170.91,-0.16,245.53,-0.16,11.76,1692.53,16.68 5.41,5502,0.35,169.74,-0.16,244.67,-0.16,11.76,1728.79,16.68 5.51,5531,0.35,168.95,-0.16,244.67,-0.16,9.70,1724.44,16.68 5.61,5539,0.00,143.08,-0.16,132.56,-0.16,10.00,1605.51,13.63 Here's a copy of a datalog that I'm trying to graph. When I copy and paste from wordpad into the csv grapher it pulls the items logged but only two lines of data. Any ideas? It copied the whole log when pasting here. |
| Not Ranked : 0 score Works for me. Make sure you check the boxes of the items you want, and also pick the colors. |
I noticed that when I paste in the text box each time stamped data line is split into two lines. | |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score Try a different browser.
__________________ Some things. |
| Not Ranked : 0 score Chrome works. Thanks |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Great job! Thanks for the graphing tool!
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
| BoooOost ! ![]() Join Date: Feb 2010 Location: Montreal, QC, Canada
Rep Power: 154 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
| Not Ranked : 0 score Does not work anymore...Account suspended
__________________ 2010 Mazdaspeed3 - Freektuned with some bolt ons. |
| CSV Grapher | Y o o z | MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning | 18 | 09-20-2012 07:16 AM |
