| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Apr 2012 Location: Manchester, NH
(Thread Starter) | Not Ranked : 0 score Potential Factors of bad results: Wind factor of 18 mph 3rd gear and not 4th gear runs Bad Tune(I'm turrible) VD factors to apply: Tire: 215/50/17 My weight: 160 lbs. I'd love some insight beyond my insanely fugly AFR on what could be holding me back. Previous runs showed results of 296 HP, and over 310 trq. I would like to assume something wrong with the weather or something else but maybe you experts can see something in the logs that points to a potential mechanical problem. Additionally my map is attached.
__________________ Flow Student '07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs. ![]() |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score There are so many variables that could be in play. Has the map changed since the 296/310 run? Same stretch of road? How did the IATs and BATs compare? You stop meeting boost targets a around 4500 so you need to tweak WGDC and dynamics a bit.
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 2 Users Say Thank You to Mike@Stratified For This Useful Post: | Agent_Orange (02-22-2014), Emew (02-22-2014) |
(Thread Starter) | Not Ranked : 0 score Same road, I will compare IATs and BATs, and I've debated increasing WGDC at 4500+ but wasn't sure if I would just be blowing hot air at that certain range. What's a reasonable RPM to stop increasing WGDC to meet boost targets at?
(Thread Starter) | Not Ranked : 0 score Actually today's BATs and IATs were roughly 5 degrees colder than the previous run, but I do notice boost settling down to 19 by 5k in my old log, as well as 16 by 6k. One variable I have changed is I gave the BECs tables more control. On my old WOT log(290hp) they were stock OTS values of -.02 to -.15(IIRC?). The new values are -.05 to -1.10 interpolated. I MAY(not 100% sure) have decreased WGDC in my higher range (4.5k+) by say 3-5% because of chasing boost spikes before I learned much of the BEC tables. But I guess I'm also curious about whether or not I may have given the BEC table too much control? The positive end(left side) is still the stock OTS values so it isn't adding as much WG as it's technically pulling, but also I'm unsure as to whether wind factor would be throwing me off by any degree as well..
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score Like Mike said, there are lots of variables that come into play here, and ultimately it's vDyno, it's far from precision, and seeing a 30 hp swing isn't unusual. Not sure how much more power your expecting to get with those mods, but my suggestions would be to get better fuel (E85) and maybe think about a bigger intake as your g/s aren't very impressive. As far as tuning is concerned, pure boost based is shit, and from the questions your asking it seems like you may need to read more. |
| The Following User Says Thank You to Agent_Orange For This Useful Post: | Emew (02-22-2014) |
__________________ Flow Student '07 Speed6 TiGrey: SURE ID300/Shift Plate+Weight/Breather Hose, Forge BPV v2, CX-7 Antenna, ProSport Boost Gauge, Block8Head's MS6 Pod, Cobb AP v3, ITV22 1SC Plugs, TWM Short Shift, Stage 2 Clutch, JBR Shifter Bushings/Shift Knob/RMM/EGR Delete, Euro LED Tails, AutoTech FP Internals, M2 DP, ETS TMIC, Techna-Fit SS Brake Lines/Clutch Line, Hawk HPS Pads, ATE 200, MD OCC VTA v2, 3-Bar MAP, AWR TMM, CP-E RDM, Whiteline RSB, RB Rear Endlinks, Moog Front Endlinks, Bilstein HD6 Shocks, Corksport Springs. ![]() | |
Groans: 665
| Not Ranked : 0 score This is the way I learned. Some of the best information is in random posts in the middle of threads, and often times they aren't stickies. Another good method is to see what experts are posting. Going through posts by guys like: @ms3blackmica; @atvfreek; @rfinkle2; @Lex; can give you some incredible insight to everything. |
| The Following 3 Users Say Thank You to Agent_Orange For This Useful Post: |
| cobb ap: is safe tune quicker than stage 0 tune? | Fusion_MS3 | 2010 MS3 - ECU Computer Tuning | 14 | 12-16-2012 02:27 AM |
| Mercedes-Benz gears up for the demise of the G-Class with BA3 Final Edition and Edition Select | Haltech | Automotive News | 0 | 05-05-2011 02:40 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
| In Tune With the Past: Arden re-issues limited-edition AJ18 XK | Haltech | Automotive News | 0 | 07-01-2009 05:10 PM |
