Like Tree37Likes
 Old 01-18-2012, 03:34 PM   #1
Neutral  +4 score
Default KR explained
I have a lot of questions regarding KR and I wanted to clarify things a little about several nuances of KR that are NOT caused by detonation and the timing curve in the map.
1. Spool up KR. Here you will see a bit of KR (anything under 1.0 I just take as a "we've reached the efficient point" sign). This is common and not to worry you if it dies down like it does here and does not exceed 2.0. Remember the ECU drops KR in steps over a certain period of time and you can see this here and in all logs. If the KR is dropping it means no more knock is detected and the ECU is returning the timing to the base table. Why in this log? Look at your BATs - they are higher than in other logs.
2. High RPM KR that is a result of mechanical noise/shifting. Again the same log you will see that over 6K RPM there is a 0.7-1.0 or so of KR creeping in. This is a sign of mechanical noise but at 0.7 it's not something to really worry about. Then take a look at the 2.1 value there before it goes to 0. That is where you let off the throttle and the motor moved in the engine bay causing again mechanical noise. This is very common - a fast spike just as you shift or right when you let go of the throttle. This is not knock - just the engine moving around in the engine bay - don't worry about this. You can decrease the sensitivity of the sensor in the high RPM region. However if it is very high KR (2-3+), you're either indeed detonating or have a VERY noisy engine (see comment below)
If you see consistent high KR (5+ during WOT runs) and it is not due to timing or during shifting this is caused by other mechanical parts. Anything from a timing chain, to injector seals, to a bent rod. So keep an eye and diagnose this instead of trying to tune around it. Below is that turned out to be KR caused by a bent rod. As you can see it ramps right up to the max 5.95 and sits there regardless of timing (which drops into negative numbers).
3. Cold engine KR. When the car is not fully warmed up (even if the temperature gauge tells you it's fine) you may experience more KR than usual going up in the RPM range or under boost. This is because the engine internals have not reached operating temperature and expansion and are just noisier. Rule of thumb is to drive the car for at least 15 minutes before doing full WOT runs ... or to get an oil temperature gauge. Either way, if the car is cold, it's best to let it warm anyways before really getting on it so this KR serves as a friendly reminder.
ADDED March 10 2013
Part throttle knock - some insight
I have recently swapped out the ECU in my car for the latest part from Mazda (It's a gen1 2008.5). This is a different part number from what came in the car and it supersedes all other ECU part numbers for gen1s (there are many). The interesting aspect is that the part throttle and warm-up KR have significantly decreased or completely disappeared with no other changes to the car. Before readings in the 5-6+ KR range were normal as the car warmed up or on the first run of the day as well as at part throttle. Now they are either at 1* KR or below. No hardware changes, no tuning changes, no weather changes, just an ECU swap.
Now how does this play into the whole KR bit? While we have access to some of the knock sensor tuning tables via ATR and VersaTuner, we don't have access to the filtering algorithm (in the ECU firmware) or hardware. Remember that the knock sensor is a microphone and the ECU filters that signal to interpret knock. Mazda may have updated the hardware or algorithms responsible for this. This is further supported by the fact that the newer cars (gen2) don't suffer from this "part throttle knock" syndrome nearly as much as the gen1s.
What does this mean? Well it means that the algorithm was perhaps overly sensitive picking up "false knock" initially and not just scaring enthusiasts but losing some efficiency at part throttle since timing was lowered. This can also put to rest some of the fears that people (mainly gen1 owners) have when they see high part throttle KR readings.
The Following 253 Users Say Thank You to Lex For This Useful Post:
-cj- (05-08-2012), 08.5MS3 (04-24-2012), 08cosmic3 (01-19-2012), 09Speed3Z (01-19-2012), 09speedaddict (01-19-2012), 12blkms3 (02-15-2014), 2.0t03speed (08-08-2013), 3starmagnum (08-23-2013), 671 grains of reason (06-20-2012), 86AmishMs3 (01-18-2012), ABolewski (12-11-2012), ABOSWORTH (03-30-2014), adlpb (05-09-2012), Agent_Orange (03-22-2014), ak_spray (01-22-2012), alfre127 (02-27-2013), Alpha (01-19-2012), altaprecision (01-05-2014), Amnesiac (07-06-2014), ANGRYEAGLE (04-30-2015), Arnie1229 (01-13-2015), aromig (02-05-2014), Atticaz (12-09-2015), atvfreek (01-18-2012), az_jayc (03-16-2013), backward_0 (01-18-2012), Badger_ (08-23-2014), BAT-man (12-18-2012), bayarea_pat (01-18-2012), bazzarino (05-20-2012), bertrand_CX_7 (01-24-2012), best_predator (02-27-2013), BigJimMs3 (01-18-2012), Black Metal (01-18-2012), blackms3_71 (02-13-2013), BlueStreak (01-18-2012), BMC (05-07-2015), BobbleHead (01-18-2012), Boost Addict (01-18-2012), BooSTed_Hatch (06-20-2013), Boost_creep (01-18-2012), brand0llaz (10-20-2015), Brennan (04-21-2012), Bucker (01-18-2012), bunta (03-16-2014), ButtholeRedMS3 (01-03-2016), BZiggy10 (01-29-2014), cardoc4u (10-12-2016), Cataphract_40 (01-19-2012), charlesfist (02-15-2012), chaser27 (01-07-2014), cheskonator (09-08-2013), Chimmike (01-20-2012), CJM (01-19-2012), Coaststarlight (05-13-2012), Colin1337 (05-03-2013), daafisch (01-18-2012), dagrimey1 (04-09-2014), Dahouse702 (01-22-2012), Dano (01-20-2012), dantes5823 (06-07-2012), darkcherry (08-06-2012), daztdMS6 (01-18-2012), dereeek (01-18-2012), derek13p (09-20-2013), dgus429 (05-08-2012), DickFitzwell (05-07-2012), DingoDave (04-30-2012), DISIindahead (01-18-2012), djuosnteisn (02-19-2012), Dmurray06 (02-08-2012), dohc (02-16-2014), Domino81 (01-19-2012), Donut (06-18-2013), doubleflusher (05-05-2012), dougefresh_ (01-18-2012), Downmented (02-03-2012), drewb457 (03-22-2013), dr_banano (03-27-2012), Dubcnea (05-16-2012), DuBz (05-05-2012), eljefe62 (04-04-2012), f-castrillo (01-19-2012), fasteddie128 (12-07-2014), feldm4n (02-23-2012), Fi5H (09-12-2013), Fjager (01-17-2014), Fobio (04-08-2012), fooqr (03-15-2012), franz (02-15-2012), Funkster777 (10-01-2013), fywdyl (01-18-2012), Geo13 (10-03-2013), gmoney542 (04-10-2014), goHAMM (06-03-2014), grobbins (02-03-2016), GrumpyMPS (05-02-2013), GTISPEED3 (08-08-2014), guitarzan134 (07-16-2012), H3R3TIC (01-23-2012), hartlch (04-30-2012), helmetface (01-18-2012), iamareios (05-15-2016), iammike (08-17-2013), IMASA (03-09-2012), Ingle (01-20-2012), IshiKage (01-18-2012), ItsNox (06-19-2013), J'sSpeed3 (01-19-2012), Jabl3s (05-13-2014), JacksonMS30 (01-22-2012), Jake5713 (01-20-2012), JasonMzdSpd3 (04-01-2012), JeffroMS3 (10-31-2013), jeopardy98 (03-25-2012), Jlandry67 (04-08-2014), jman46 (01-18-2012), Joellc2434 (01-18-2012), johnredding (07-22-2012), Jra2011speed3 (12-09-2013), jracer (01-18-2012), jrlms6 (05-07-2012), Juyoung (02-23-2013), K.Mah (10-19-2012), kabobulate (04-04-2012), KayWhy (12-31-2013), Kellerspeed3 (02-23-2013), keridil (05-30-2014), kgb (01-20-2012), King Scumbag (02-20-2013), kish89 (03-06-2012), kladuscan (05-27-2013), kmac (01-18-2012), krazycoble (01-19-2012), Kydizzle (02-02-2012), kylec_2003 (06-01-2012), LatinKraze (02-06-2012), letzleta (01-19-2012), LumberJack (02-27-2013), mac_dre (04-05-2012), magicka (04-16-2012), maisonvi (01-19-2012), manelscout4life (01-18-2012), manselainen (01-22-2012), Mase (05-24-2012), mayer (01-20-2012), MazdaBoy2.3 (11-14-2012), mazdamx3freak (01-18-2012), mazdapangolin (01-08-2014), mazdaspeedemon3 (05-10-2012), Mchart (04-07-2012), MD1032 (06-28-2015), mdl3v8 (01-19-2012), Meder (02-16-2012), meicalnissyen (02-06-2017), Menace1 (12-19-2012), metalgear386 (09-01-2013), Mfinlay04 (02-01-2015), Micha (06-25-2012), Mike@Stratified (02-24-2012), MikeyLikes (07-03-2013), Mistersix (03-20-2012), moomooz12 (10-08-2012), MPSdriver (01-20-2012), mroclimbr (04-15-2012), mrsaxbies (01-03-2014), ms3bamf (01-18-2012), ms3blackmica (12-30-2012), mysleeper6 (02-15-2012), Mythyk (09-20-2012), myt_tuf1 (01-29-2013), Nathan 6 (06-30-2012), Nitr0EngiE (12-09-2012), NJSPEED3 (01-18-2012), NoRegrets (05-05-2013), nycMS3 (04-07-2013), obijack (01-19-2012), Oliverms3 (01-18-2012), omgvance (04-03-2012), Onelovesoccer (07-22-2013), p057 (01-19-2012), PapaBruno (04-12-2017), PaulDiGi (01-19-2012), pebenito (01-19-2012), Pointless (10-29-2012), Pseud0logik (08-23-2012), Pu Manchu (09-30-2012), Rainmens (11-14-2012), Raymond (04-19-2013), razortechrs (07-24-2014), rfinkle2 (01-18-2012), rghispanic88 (01-18-2012), ricknm (04-30-2012), rigor (01-23-2012), rob ms6gt (03-04-2012), robertof (01-19-2012), Rocklobsta1109 (02-21-2012), ScarMS3 (01-18-2012), Scoobs (01-21-2012), Scribbles (01-20-2012), shaftyella (01-20-2012), shawn. (01-18-2012), Sid3wayS (01-18-2012), Sideswipe (05-30-2012), silvapain (01-19-2012), SJP0tato (01-18-2012), skeeter149 (01-18-2012), skeurton (05-07-2012), SleeperHatch (02-15-2012), SLOWHATCH (01-18-2012), Snappy (11-16-2015), Snotrocket (04-08-2012), spals (02-21-2013), SparkySparks (06-03-2013), speed d3mon (01-18-2012), speed23 (01-18-2012), speeda (12-23-2012), speedster3_08.5 (11-21-2013), speedy308 (09-18-2012), Stealth01 (01-18-2012), stp (01-18-2012), svd (10-02-2013), SweetJP (01-18-2012), Swinger13 (06-10-2013), taf0422 (04-24-2012), Teethkikr (01-24-2012), the public enemy (04-02-2015), thepatient77 (04-21-2015), TheRealDefman (05-17-2012), theschrum (01-02-2014), TiGraySpeed6 (01-18-2012), Tokay444 (01-18-2012), Tomas (01-18-2012), tomek_46 (01-18-2012), tommyboy (04-24-2014), torquemaniac (12-10-2016), TRex (01-18-2012), udntknw (02-17-2013), uncorked11 (01-18-2012), Vader (01-19-2012), Vinnie (04-29-2012), voodoo2crue (02-25-2015), vtdone (04-11-2013), wallenberg (08-24-2013), wankular (01-18-2012), warlord (02-15-2012), WetzMS3 (03-11-2015), WillyH (01-18-2012), Worbit (07-25-2012), xtasy (01-18-2012), XxSmarTz (02-17-2014), zpele (03-26-2012), []V[]addog (11-19-2012)
 Old 01-18-2012, 03:35 PM   #2
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
Neutral  +1 score
I officially propose we change Lex's username to "Professor Lex" and make him the wheelchair-bound, bald leader of the "Lex-Men."
aromig, john.e.stoner and Robi like this.
Stealth01
2006 Mazdaspeed6 GT
The Following 38 Users Say Thank You to Stealth01 For This Useful Post:
Addikted To Boost (07-24-2014), ak_spray (01-22-2012), Alpha (01-19-2012), aromig (02-05-2014), BlueStreak (01-18-2012), BobbleHead (01-18-2012), Cataphract_40 (01-19-2012), daafisch (01-18-2012), Dano (01-20-2012), darkcherry (08-06-2012), dereeek (01-18-2012), derek13p (09-20-2013), dougefresh_ (01-18-2012), I<3Groceries (03-14-2012), JacksonMS30 (01-18-2012), Jake5713 (01-20-2012), Juyoung (02-23-2013), J_Logik (05-14-2012), kmac (01-18-2012), LumberJack (02-27-2013), Micha (06-25-2012), mWindu (11-14-2012), Mythyk (09-20-2012), nycMS3 (04-07-2013), Oliverms3 (01-18-2012), p057 (01-19-2012), Raymond (04-24-2013), rghispanic88 (01-18-2012), ScarMS3 (01-18-2012), SLOWHATCH (01-18-2012), speed23 (01-18-2012), Speed3Power (03-27-2014), Tokay444 (01-18-2012), uncorked11 (01-18-2012), Vader (01-19-2012), Vinnie (04-29-2012), Weazsel (11-18-2012), Worbit (07-15-2012)
 Old 01-18-2012, 03:42 PM   #3
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
@Lex my buddy just got back from getting his car tuned. He did like 20 runs with no knock and is now hitting 5.9. He says it does it all the time now. I told him to watch for what you stated. Hes going back in to get tuned again, so we'll see what happens.
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
 Old 01-18-2012, 03:46 PM   #4
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
good shit, Lex. I mean, The Professor. :bows:
2015 Mazda 6
 Old 01-18-2012, 03:46 PM   #5
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
fucking kr
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
 Old 01-18-2012, 03:56 PM   #6
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
So I've got a question, What temp should the oil be at to be considered "warmed up"?
TEAM LUXURY
The Following 4 Users Say Thank You to Sid3wayS For This Useful Post:
Arnie1229 (01-13-2015), bertrand_CX_7 (01-24-2012), Jake5713 (01-20-2012), SLOWHATCH (01-18-2012)
 Old 01-18-2012, 03:59 PM   #7
That's a classic sign of something mechanical rattling in the motor unless he filled it up with 87 fuel.
That is a very deep topic. If you have a gauge, consider the temperature you see after 20 minutes of normal driving warm. If you don't have a gauge, drive normally for the first 15-20 minutes without intentionally doing WOT pulls to redline.
Ms3=good_times likes this.
Last edited by Lex; 01-18-2012 at 03:59 PM. Reason: MSF Database - Automerged Doublepost
Atticaz (12-09-2015), DISIindahead (01-18-2012), dougefresh_ (01-18-2012), Juyoung (02-23-2013), kmac (01-18-2012), Sid3wayS (01-18-2012)
 Old 01-18-2012, 04:08 PM   #8
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
I have both a pressure and temp guage. not knowing how accurate the pressure guage is before it warms up, when my engine is first started cold pressure is around 80 psi, if I was to drive right away it maxes out my guage. once the temp guage is 180ish degrees then I see 15-20 psi at idle and 60 psi driving. coolant temp gets hotter faster so when it reaches 180 the oil is normally 150 degrees. I usually drive off for wot runs once the coolant is 180 at least which is measurable in a cobb ap
The Following 7 Users Say Thank You to crazyp For This Useful Post:
bertrand_CX_7 (01-24-2012), dougefresh_ (01-18-2012), EdMazdaMan (07-29-2012), p057 (01-19-2012), rfinkle2 (01-18-2012), Sid3wayS (01-18-2012), SLOWHATCH (01-18-2012)
 Old 01-18-2012, 04:09 PM   #9
Once my coolant temp reaches 175*f, I no longer get part throttle or wot knock.
(well, the type caused by low engine operating temp anyway).
crazyp (01-18-2012), dougefresh_ (01-18-2012), p057 (01-19-2012), SLOWHATCH (01-18-2012)
 Old 01-18-2012, 04:13 PM   #10
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
Great write up, this should definitely be man a sticky. A lot of people are always asking about these cases of KR.
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
 Old 01-18-2012, 04:15 PM   #11
hank25's Avatar
Posts: 71   (View Stats)
hank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant futurehank25 has a brilliant future
Cruising knock has been driving my crazy! Car is great at WOT and thats what matters but god that can sure be annoying! ! I have seen it up to 8.1.
Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ
hank25 is offline   Reply With Quote
The Following 3 Users Say Thank You to hank25 For This Useful Post:
DingoDave (04-30-2012), Juyoung (02-23-2013), ScarMS3 (01-18-2012)
 Old 01-18-2012, 04:24 PM   #12
@Raider...can we get a sticky?
Juyoung (02-23-2013), Raider (01-18-2012)
 Old 01-18-2012, 04:28 PM   #13
speed d3mon's Avatar
Posts: 302   (View Stats)
speed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the worldspeed d3mon is the leader of the world
this is exactly the info i needed. thanks so much!
speed d3mon is offline   Reply With Quote
 Old 01-18-2012, 04:38 PM   #14
atvfreek's Avatar
Posts: 7,787   (View Stats)
I agree on sticky as well. Nice write up Lex!
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
altaprecision (10-22-2014), Juyoung (02-23-2013)
 Old 01-18-2012, 04:38 PM   #15
IshiKage's Avatar
Groans: 278
s@Lex whats your theory on why it seems like 08.5 and 09 Speeds do no react well to FFS'ing?
2015 Mazda 6
 Old 01-18-2012, 04:41 PM   #16
Stealth01's Avatar
Groans: 201
And btw folks -- them be MY logs lol. So my noobiness has been turned around into a learning experience for many. YAY!
@Lex -- played with the 1.6 map a bit and had no KR over 1.4, even during a 0-60 pull. And what I did have fit both your categories above. Only took one log, so I'll send you more later in the week, when I'm awake enough to drive safely again.
Stealth01
2006 Mazdaspeed6 GT
The Following 4 Users Say Thank You to Stealth01 For This Useful Post:
DISIindahead (01-18-2012), dougefresh_ (01-18-2012), IshiKage (01-18-2012), rfinkle2 (01-18-2012)
 Old 01-18-2012, 06:16 PM   #17
Stuck...Ill reward op when I get a chance.
Bockie84 likes this.
The Following 9 Users Say Thank You to Raider For This Useful Post:
atvfreek (01-19-2012), dougefresh_ (01-18-2012), Juyoung (02-23-2013), rfinkle2 (01-18-2012), rigor (01-23-2012), SLOWHATCH (01-19-2012), Stealth01 (01-18-2012), TiGraySpeed6 (01-18-2012), uncorked11 (01-21-2012)
 Old 01-18-2012, 07:05 PM   #18
I don't think it's just those cars. I think there is an issue with the FFS logic where the car does not return to commanded AFRs after a shift and I've seen it in MS6s as well.
 Old 01-18-2012, 07:13 PM   #19
Updated OP with bent rod KR.
Juyoung (02-23-2013), rfinkle2 (01-19-2012), SLOWHATCH (01-19-2012), Stealth01 (01-19-2012), TiGraySpeed6 (01-18-2012)
 Old 01-18-2012, 07:19 PM   #20
TRex's Avatar
Posts: 3,139   (View Stats)
so...you seem to explain everything but actual predetonation knock.....so what exactly does predetonation knock look like?
The Following User Says Thank You to TRex For This Useful Post:
 Old 01-18-2012, 07:37 PM   #21
PaulDiGi's Avatar
Posts: 42   (View Stats)
PaulDiGi is a splendid one to beholdPaulDiGi is a splendid one to beholdPaulDiGi is a splendid one to beholdPaulDiGi is a splendid one to beholdPaulDiGi is a splendid one to beholdPaulDiGi is a splendid one to behold
@hank25 I agree with that cruising kr being annoying as hell. Totally fine during WOT but I consistently see 6.0 until the slightest load.
timing chain issue? or nothing to worry about like I have heard/read a million times.
2006 Mazdaspeed6: Cobb AP Stage 1 - Cobb SRI - ETS TMIC - OBX Testpipe - Corksport Catback - Mazdaspeed Coilovers - Sure RMM - TWM Stage 2 - ITV 22 - Varrstoen 2.2.1 - Hankook V2 Ventus.
Anddd when the temperature is above 50 degrees:
2009 Ducati 848
PaulDiGi is offline   Reply With Quote
The Following User Says Thank You to PaulDiGi For This Useful Post:
 Old 01-18-2012, 07:40 PM   #22
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
Ahhhh yes the good olll fucking cruising then look down at my AP and see 4.3kr for no god damn reason KR lol.....
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
The Following User Says Thank You to BigJimMs3 For This Useful Post:
 Old 01-18-2012, 07:48 PM   #23
atvfreek's Avatar
Here is a log of some "real knock". You can see the kr, and then as it starts to put timing back in, it pulls more. Sometimes you will see this if you fill up at a shitty gas station or driving real hard when the tune is pretty aggresive. This happened to be after a hard shift. The kr is less than 2, so it's well within the pcm's capability of pulling timing.
Sorry for just the log and no pic.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
bigriver (01-18-2012), Lex (01-18-2012), ms3bamf (01-19-2012), rfinkle2 (01-18-2012), TRex (01-19-2012)
 Old 01-18-2012, 08:06 PM   #24
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
awesome thread
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
Lex (01-18-2012)
 Old 01-18-2012, 08:15 PM   #25
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
@Lex Thank you for spelling this out clearly.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
The Following User Says Thank You to uncorked11 For This Useful Post:
Lex (01-18-2012)
 Old 01-18-2012, 08:19 PM   #26
bigriver's Avatar
Posts: 1,123   (View Stats)
Here you go. Hope this posts okay. [shit, pic fail] Have to post from my home computer.
bigriver is offline   Reply With Quote
The Following 3 Users Say Thank You to bigriver For This Useful Post:
atvfreek (01-19-2012), rfinkle2 (01-18-2012), TRex (01-19-2012)
 Old 01-18-2012, 08:50 PM   #27
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Excellent write up!
 Old 01-18-2012, 10:01 PM   #28
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
excellent info lex, thanks!
340hp / 371tq
 Old 01-18-2012, 10:04 PM   #29
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
+1 same thing for me
TriO is offline   Reply With Quote
 Old 01-19-2012, 05:39 AM   #30
atvfreek's Avatar
Just wanted to add to this a little. This kr only happened on one run out of a bunch with this map, so I left the map as is for the tune and he still hasn't had another run like that.
Also if you happen to fill up at a mom and pops gas station, and start getting kr that you haven't been getting. Just ride out that tank easy until you can refill at a known good station.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 01-19-2012, 07:34 AM   #31
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
any familiar characteristics of bent-rod knock?
or does it just fall under the "engine noises" category?
Awesome writeup that puts a little more mind at ease. Thanks.
p057 is offline   Reply With Quote
 Old 01-19-2012, 11:42 AM   #32
Stealth01's Avatar
Groans: 201
And thank GOD those logs are NOT mine. LOL.
Stealth01
2006 Mazdaspeed6 GT
 Old 01-19-2012, 11:56 AM   #33
Domino81's Avatar
Posts: 5,081   (View Stats)
Subbed.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 01-19-2012, 01:44 PM   #34
Most people get a vibration through the clutch before catching a log that shows knocking from a bent rod.
BigJimMs3 (01-19-2012), p057 (01-19-2012)
 Old 01-19-2012, 03:33 PM   #35
The one I posted didn't. Not that he could tell at least. Car ran like this for 2 weeks before venting #4 in front of the mall.
Dano (01-20-2012), rfinkle2 (01-19-2012)
 Old 01-19-2012, 04:30 PM   #36
Insane how it rarely happens @ high throttle.
So many vented blocks during casual driving.
I understand the idea that the damage has been done, but it is just crazy how people seem to vent the block @ low rpms.
crazyp (01-19-2012)
 Old 01-19-2012, 05:19 PM   #37
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Fast forward to 2:14
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
The Following 7 Users Say Thank You to Cataphract_40 For This Useful Post:
Dano (01-20-2012), darkcherry (08-06-2012), DingoDave (04-30-2012), Juyoung (02-23-2013), kgb (01-20-2012), Sid3wayS (01-20-2012), TriO (01-19-2012)
 Old 01-19-2012, 06:23 PM   #38
It's probably just statistics. How much time do we spend at part throttle versus at WOT? Also it always seems to happen after a shift which we again do many times a day.
rfinkle2 (01-20-2012)
 Old 01-19-2012, 06:30 PM   #39
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
I'd say about 75% of the time, i get some kr less than one on my logs, usually right after spool at max boost, and it drops it in steps.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
The Following 3 Users Say Thank You to G26 For This Useful Post:
bertrand_CX_7 (01-24-2012), rfinkle2 (01-20-2012), speed14 (01-24-2012)
 Old 01-20-2012, 12:59 AM   #40
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Any thoughts on KR in a particular gear, I'm getting anywhere between 2-4KR @~4.5k but only in 5th gear@ WOT??
@Lex @rfinkle2
Tuned with by
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/kr-explained-102609/
Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-04-2014 12:27 AM
?????????. ?????? vs ????????, ??? ??????? This thread Refback 12-07-2013 07:44 PM
Versatuner on Gen 2 Experience This thread Refback 05-02-2013 04:42 AM
/v/ - Vehicles This thread Refback 11-01-2012 08:19 PM
Cobb Access Port FAQ This thread Refback 08-31-2012 05:49 AM
MS6 ECU Tuning Starting Point for Noobs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-29-2012 12:54 PM
Okay, WTF was this? - Page 11 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-20-2012 11:12 AM
MS3/MSF: KR explained by Alex@Stratified This thread Refback 05-08-2012 10:00 PM
My Logs - Page 2 This thread Refback 05-08-2012 09:58 PM
Snotrocket's Tuning/Logs - Page 6 This thread Refback 04-08-2012 10:14 PM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 04-05-2012 04:10 AM
Getting Knocked Up..what gives? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-21-2012 02:49 PM
Boost Control Explained - EBC / MBC flyrevs2 MazdaSpeed 3/6 - ECU Computer Tuning 4 02-19-2010 12:04 PM
PID tuning explained wassup61 Mazdaspeed3/6 General Discussion 7 03-21-2009 09:47 AM
Page generated in 0.64845 seconds with 47 queries
