| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Jun 2011 Location: Dallas TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 654
Groaned at 6 Times in 1 Post
![]() Join Date: Aug 2010 Location: BC, CANADA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Not too bad, but consider getting a new fuel pump or internals. Your AFR's dip into the 12's when your pump is down to 1000psi, though you're not getting any KR. |
(Thread Starter) | Not Ranked : 0 score ok thank you thats what i was trying to see and thats on a stage 1 map i cant even run a stage 2 with my ap my fuel psi drops way low |
(Thread Starter) | Not Ranked : 0 score Log from last night a little better i want to do a cal on it but im still confused |
| Not Ranked : 0 score Looks decent, KR <1.0, just dropping fuel pressure. What are your AFR targets? Read up on Abilor's tooning guide, do the closed/open look fixes. Might want to drop the boost til you get a new pump. |
(Thread Starter) | Not Ranked : 0 score ive read threw his tooning guide but still find myself lost |
![]() Join Date: Feb 2011 Location: Lusby, MD
Rep Power: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score Yea i wouldnt wail on it too much until you fix the fuel pump. Not much in the way of tuning for more power until you do that. You could do a maf cal but you would need to do a log specifically for that (maf g/s and volts, STFT and LTFT)
__________________ 06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts | KILLAH BUILT |
![]() Join Date: Apr 2009 Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 735
| Not Ranked : 0 score What mods do you have? Maybe post in sig.
__________________ Traded |
Wow. You could really tear it up with fuel pump internals.
__________________ Traded Last edited by Abilor; 07-03-2011 at 08:58 PM. Reason: MSF Database - Automerged Doublepost | |
(Thread Starter) | Not Ranked : 0 score Im running a stage 1 map
__________________ cpe intake cobb turbo inlet hks bov (atmo) w2 dp borla cbe cobb ap |
| Not Ranked : 0 score You have a DP installed though?
| So..Lost my key and FOB...help? HOW TO.. | the95z | MazdaSpeed 3 - How-To's | 42 | 02-20-2015 09:55 PM |
| Lost Acceleration | lwrees72 | 2010 MS3 - Engine, Transmission & Driveline | 39 | 08-22-2012 06:40 PM |
