| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Feb 2012 Location: Tempe, Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 6 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score The long term, Maf volt, and MAF Airflow |
![]() Join Date: Jul 2010 Location: Leesburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,641
Groaned at 56 Times in 37 Posts
| Not Ranked : 0 score it looks like you are making adjustments in the wrong direction. Your STFTs get worse with every log in virutally every break of your g/s. are you sure you are calculating your adjustments correctly? MAF cal is a tedious process, I know. But misplacing a decimal or +/- will throw off your calcuated adjustments
__________________ cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com 311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM] 12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14] |
(Thread Starter) | Not Ranked : 0 score I have not adjusted anything yet this is still OTS stage 1. This is why I am confused since it looks so wrong on the logs from each log and I did not do anything different in each one.... |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| Not Ranked : 0 score Did you flash it and went straight into a maf cal? Drive it around for a bit then try it again. I did a maf cal for one of my guys and he logged i think the next day and his first wot log was all sorts of fucked up. Then after that it was on point. Did another maf cal the next day and all were within 3% |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score ^ what he said, if you just flashed it. it takes time for it to learn
__________________ Damond Built Speed 6 |
| Not Ranked : 0 score Have you allowed your car to learn the newly flashed trims? Your ecu is very smart and constantly making adjustments. If you took these logs immediately after a flash, then your ecu is still "learning", which may explain the varied results If you haven't made any adjustments, focus on getting cleaner logs for now. Your g/s jumps a lot in your logs. The cleaner log you have, the easier the process is.
(Thread Starter) | Not Ranked : 0 score it has been on OTS flash since 1000+ miles ago |
| Not Ranked : 0 score That being said, your ecu is "just doin it's thang". If you haven't touched your tables... get some clean logs and have at it. Don't be scured!
| The Following User Says Thank You to MS3inDC For This Useful Post: | omgheyitskenny (05-01-2012) |
![]() Join Date: Feb 2012 Location: Dana Point, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,483
Groans: 107
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score The Logs look OK. Few things you need to do. 1. Start the log at about 1500 RPM so you can better see the LTFT <6g/s 2. Accelerate a little bit faster. Start out the same but once you get to 3k RPMs or so start slowly accelerate faster. You want to get to 100-130 g/s. In these logs you are barely hitting 100+g/s and you are ringing the engine out to 6600 RPMs or so, no need. You just need to stay in closed loop its not that hard. Your breakpoints look fine. I did my first MAF cal a few days ago, and it looked just like this. All the guides I read had more breakpoints than mine, so I was also confused as hell. I poked around and realized my map (Stage1+Aeros SRI OTS map) only had breakpoints at 5.7g/s, 18g/s. After 18g/s it will stay the same unless you change the breakpoints. I calibrated my MAF from 0-5.6, 5.7-18, 18.1+ with the logs I had. After I did that, I added new breakpoints in the map. I forgot where they were and I don't have ATR here. I forgot what I set my breakpoints to, but now it's more accurate. I actually ended up calibrating it well, I will fine tune it once I get more miles on it, and I will have more breakpoints to work with to make it more accurate.
__________________ 2012 MS3 Stratified 91 Cobb AP | UR FMIC, TP, CBE | Autotech Internals Forge v2 BPV | Denso ITV22 | SURE Aeros Full3 ID283* JBR 88a RMM/TMM, 70a PMM, OCC, RSB, TIGs, Coolant bypass, EGR delete, Bushings, Knob Aeroforce Interceptor | Defi Boost gauge *Product is advertised as ID300 |
| The Following User Says Thank You to Keko For This Useful Post: | omgheyitskenny (05-01-2012) |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score Everything looks fine...for the first few breakpoints after the first you could add 2% but really it doesn't look like it needs touched And btw 3rg gear works better.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 05-01-2012 at 01:27 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | omgheyitskenny (05-01-2012) |
(Thread Starter) | Not Ranked : 0 score Alright thanks guys will attempt again after lunch |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score Keep in mind Abilor's guide is a bit outdated. Cobb's new OTS breakpoints are: 0-5.7 5.7-18 18-full sensor range
__________________ [SIGPIC][/SIGPIC] www.dizzytuning.com www.facebook.com/dizzytuning |
![]() Join Date: May 2009 Location: Calgary
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 892
| Not Ranked : 0 score Looks pretty good to me.... Closer than mine are anyway |
| Fuel pump confusion | oh_yeams6 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 04-08-2011 11:27 PM |
| Lotus's Cool Confusion | Haltech | Automotive News | 0 | 11-03-2010 12:27 AM |
| Tuning Confusion... | MS3KO | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 04-07-2010 11:52 AM |
| motor mount confusion | mexicant | MazdaSpeed 3 - Engine, Transmission & Driveline | 62 | 01-03-2009 03:57 PM |
