Like Tree3Likes
 Old 10-31-2008, 11:56 AM   #1
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
OK, so regarding MAF and Timing tables... Why would one modify/adjust these...?
Am I correct to assume that if you want to adjust your AFRs, then you modify the MAF table, while if you are getting Knock, then you adjust the Timing tables?
Basically, how do you know when to adjust/mody the Timing table?
Do you only adjust the Timing table when you get Knock?
***Edited 2:17pm:***
What PIDs should we be logging? I know Laloosh uses the following:
-RPM
-AFR from sensor
-Timing Advance
-Knock Retard
-Boosted Air Temp
I understand all the PIDs except for the Boosted Air Temp. What does that tell you?
2008 Stage 3 Roush Mustang
AutoXRacer is offline   Reply With Quote
 Old 10-31-2008, 01:17 PM   #2
If you guys like, i can do a PDF for it as well that will sit attached on the first post. Just let me know when you have everything posted and ill extract it.
 Old 10-31-2008, 01:25 PM   #3
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
That's exactly right.
Yep, we're scaling the voltage from the MAF sensor in order to adjust fueling. What we're essentially doing is lying to the car about how much air the engine is processing. So for instance when you "add fuel," we're basically lying to the computer and telling it that we're getting more air than we actually are. So we scale the voltage "up" which increases fuel delivery. So we're just tricking the car into injecting more fuel, and we use the MAF sensor to accomplish that.
Although knock can be affected by many variables, timing is most closely coupled to knock. Ignition timing dictates when the plug fires, and typically it'll fire just before the piston reaches top dead center on the compression stroke. As you can imagine, if you start the combustion event too early then the piston will be trying to compress an expanding air/fuel mixture. If the event starts early enough the pressure in the cylinder gets really high, and the air/fuel mixture burns uncontrollably and auto-ignites. This is what we want to avoid. The game here is to balance how much cylinder pressure we run. Cylinder pressure increases the most with boost and timing increases.
The reason why timing is so tricky to tune is because it isn't the only factor that affects knock, and the tuner needs to understand minimum best timing, and that more timing isn't necessarily better even if there is no knock present. Typically when I'm doing tuning off of the dyno I stick to removing timing in critical regions, which I'd be happy to discuss.
-RPM
-AFR from sensor
-Timing Advance
-Knock Retard
-Boosted Air Temp
RPM- We need to know this to understand "when" we're making changes.
AFR - Good feedback for air/fuel tuning. Gives some indication as to how much fuel should be added/removed.
Timing Advance - Timing advance tells a lot about how the car is running. Low timing advance (before tuning) could indicate that there's a problem, and that the ECU is pulling timing for some reason. It's also important to have some indication as to how much advance the engine is running.
Knock Retard - The more knock retard the ECU registers, the more knock there is. The amount of timing the ECU pulls in response to knock is proportional to the knock event. You can use the KR to indicate how hot (or poor) a tune is.
BAT - This one isn't as important, but it can help explain weird knock events, or issues with the turbocharger.
Zai_MS3 likes this.
The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post:
atenza_freak (01-27-2010), FezMS6 (01-09-2009), Zai_MS3 (03-27-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/standback-tuning-dummies-guide-official-q-14296/
[Mazda 3 MPS] ECU tunning ? glod wiedzy This thread Refback 08-02-2013 03:24 PM
[Mazda 3 MPS] ECU tunning - glod wiedzy This thread Refback 06-29-2012 04:58 AM
SoCal Standback help This thread Refback 05-16-2011 11:44 PM
standback tuning for dummies - Zuula Search This thread Refback 05-13-2010 12:43 PM
mazdaspeed standback maps - Zuula Search This thread Refback 05-05-2010 08:32 PM
mazdaspeed roush vent install - Zuula Search This thread Refback 03-22-2010 09:19 PM
Day of 1/3/2010: Top 50 of 183 Referring Pages This thread Refback 01-04-2010 10:00 AM
Day of 12/17/2009: Top 50 of 199 Referring Pages This thread Refback 12-18-2009 08:36 AM
Day of 12/2/2009: Top 50 of 217 Referring Pages This thread Refback 12-03-2009 08:20 AM
Day of 10/6/2009: Top 50 of 204 Referring Pages This thread Refback 10-07-2009 08:38 AM
Day of 10/1/2009: Top 50 of 200 Referring Pages This thread Refback 10-02-2009 08:52 AM
Day of 9/13/2009: Top 50 of 181 Referring Pages This thread Refback 09-14-2009 08:57 AM
Day of 7/29/2009: Top 50 of 195 Referring Pages This thread Refback 07-30-2009 08:07 AM
Day of 6/18/2009: Top 50 of 222 Referring Pages This thread Refback 06-19-2009 07:53 AM
Day of 6/16/2009: Top 50 of 223 Referring Pages This thread Refback 06-17-2009 08:20 AM
Day of 6/15/2009: Top 50 of 195 Referring Pages This thread Refback 06-16-2009 07:55 AM
Day of 6/10/2009: Top 50 of 188 Referring Pages This thread Refback 06-11-2009 07:40 AM
Day of 6/4/2009: Top 50 of 193 Referring Pages This thread Refback 06-05-2009 07:49 AM
Day of 5/31/2009: Top 50 of 182 Referring Pages This thread Refback 06-01-2009 08:32 AM
Day of 5/25/2009: Top 50 of 203 Referring Pages This thread Refback 05-26-2009 08:24 AM
Day of 5/21/2009: Top 50 of 213 Referring Pages This thread Refback 05-22-2009 08:29 AM
Day of 4/26/2009: Top 50 of 152 Referring Pages This thread Refback 04-27-2009 07:41 AM
Day of 3/18/2009: Top 50 of 207 Referring Pages This thread Refback 03-19-2009 04:16 PM
Day of 2/26/2009: Top 50 of 199 Referring Pages This thread Refback 02-27-2009 09:10 AM
Day of 2/22/2009: Top 50 of 176 Referring Pages This thread Refback 02-23-2009 08:04 AM
Day of 2/19/2009: Top 50 of 197 Referring Pages This thread Refback 02-20-2009 08:43 AM
Day of 1/28/2009: Top 50 of 276 Referring Pages This thread Refback 01-29-2009 07:41 AM
Day of 12/1/2008: Top 50 of 270 Referring Pages This thread Refback 12-02-2008 08:53 AM
Day of 11/30/2008: Top 50 of 252 Referring Pages This thread Refback 12-01-2008 09:19 AM
So the standback is in. - Carolina Mazdas This thread Refback 11-25-2008 08:56 AM
Day of 11/10/2008: Top 50 of 245 Referring Pages This thread Refback 11-11-2008 08:52 AM
Day of 11/3/2008: Top 50 of 245 Referring Pages This thread Refback 11-04-2008 10:34 AM
Access Tuner Race Tuning Guide Haltech
Cobb ATR Support
6 04-06-2010 12:40 AM
vta tuning on the standback bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 14 09-18-2009 08:30 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
FFS and LC in the new tuning guide twisted99
Cobb ATR Support
4 07-23-2009 12:25 AM
Cp-e standback tuning Wisedom MazdaSpeed 6 - How-To's 10 03-31-2009 07:17 PM
Page generated in 0.62511 seconds with 24 queries
